Getting 992 C2 on 4 jacks
Old Jun 27, 2024 | 08:10 PM
TheOtherDave's Avatar
TheOtherDave
Originally Posted by jhenson29
I bought rennstands and ultra low profile floor jacks for this.
I can't say I like the looks of how stable these would be. I like to have the rocking (sideways) force turned into a downward force through a direct force vector (angled tube/bar) rather
than the way these are where you are relying on a piece of angle iron where parts of the contact surface don't have any vertical load applied to keep them from bending.
In addition that angle iron doesn't look very thick to me and there is only 1 static element (at the top) keeping the bases from bending out to the front or back.
I am probably being paranoid....but it has worked for me so far in life and I have never dropped a vehicle with hundreds of lifts onto jack stands of everything up to
fighter jets in the military (also note that aircraft jack stands are just bigger versions of the ESCO design).
The jackpoint type stands look more stable to me....but they don't go very high and are not adjustable.
I guess I am going to continue to use my ESCO ones and put one of the pads towards the outside of the car for rock resistant stability.
Old Jun 27, 2024 | 08:26 PM
tomtomtomtom's Avatar
tomtomtomtom
a YouTube suggestion
Old Jun 27, 2024 | 08:44 PM
jhenson29's Avatar
jhenson29
Seemed plenty stable to me. You’re welcome to come over and give it a push the next time I’ve got it jacked.
Old Jun 27, 2024 | 09:57 PM
drcollie's Avatar
drcollie
Here’s what you don’t want to happen.
Old Jun 27, 2024 | 10:45 PM
M3Inline6's Avatar
M3Inline6
https://youtu.be/RfB7YWZ5j6E?si=bUb7Rxg6SH_UWRQk
How on earth did he not hear the creaking? He had plenty of warning.
Old Jun 28, 2024 | 12:24 AM
9.11's Avatar
9.11
Thanks for all the input, highly appreciate all responses and concern for safety.
I just found this older thread confirming the process a few of you mentioned.
https://rennlist.com/forums/992/1408...gts-today.html
Will be going with that method.
Old Jun 28, 2024 | 12:38 AM
Harbortime's Avatar
Harbortime
I bought the QuickLift and never looked back. Just buy it. Period. https://amzn.to/3zuo1tk
Old Jun 28, 2024 | 01:50 AM
Angryinch's Avatar
Angryinch
I think I’ve lifted the back from the centre of the cross member that those lower control arms connect to. Use a hockey puck or piece of wood between the jack and cross member.
7 Porsche Models That Have Aged Like Fine Wine
Old Jun 28, 2024 | 02:35 AM
wingless's Avatar
wingless
analyst
My ratcheting jack stands w/ additional vehicle specific adapters has been invaluable for safely elevating many different types of vehicles.
Old Jun 28, 2024 | 04:39 AM
null's Avatar
null
This is exactly how I do it. If I didn't need to go up and down numerous times, I find this is simple, easy, and much quicker than pulling out and setting up a set of quick jacks, while saving storage space and money. Good luck!
Old Jun 28, 2024 | 06:45 AM
Crusje's Avatar
Crusje
I was at the dealership picking up the car and there was a mobile tire guy changing tires. Should've asked him the process.
Old Jun 28, 2024 | 06:15 PM
loxxrider's Avatar
loxxrider
your car, your money. But…..read this before you go that route.
https://rennlist.com/forums/996-foru...-pic-help.html
The guy put a jack stand under the toe link... in the middle of it no less! That was never going to end well.
Even a control arm itself isn't a great place to put a jack stand since it articulates and is therefore somewhat unstable and also not going to provide maximum height for the lift. Only the mounting point for the control arm or the structural member it connects to such as a subframe should ever be used as a jack point (outside of the normal ones). It's not rocket science, but not everyone has mechanical knowledge/experience.
Old Jul 9, 2024 | 12:12 PM
9.11's Avatar
9.11
Default Success
Just finished the job, following the advice from this thread and the guide from this post: https://rennlist.com/forums/992/1408...gts-today.html
Here are some before/after pics of the powdercoat job on the wheels
Old Jul 9, 2024 | 12:29 PM
Scott P's Avatar
Scott P
[QUOTE=jhenson29;19518961]I bought rennstands and ultra low profile floor jacks for this.
OTE]
Now that's a great solution, wish I would've seen this post earlier. Oh well. I used a floor jack with a puck to lift the driver's side rear then slid a jack stand under the suspension mounting point that is encircled in blue in an earlier post. As I dropped the car very slowly on to the jack stand the driver's side front wheel started to come down so I put a block of wood under it. Worked like a charm.
Old Jul 9, 2024 | 02:42 PM
achilleas101's Avatar
achilleas101
i can't remember where I saw this, but i thought a "safe" jacking point to lift the entire rear was in the middle of the cross beam here... Seems like a pretty stiff spot. I've never lifted it from there, so can't speak to how true that is.
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
