Rocks inside body panels
Old 06-16-2024, 06:45 AM
Mitchell
7th Gear
Mitchell's Avatar
Default Rocks inside body panels
Got some small rocks wedged inside the body panels of my 992 GT3 after 10k miles.
Any ideas? They’re really in there and I don’t want to scratch the paint
pics attached for reference
Old 06-16-2024, 09:06 AM
PHX
PHX's Avatar
Don't drive near little stones? : )
Get some plastic body panel tools (Amazon is perfect for that) that are like plastic screwdrivers and clip removal tools and then lube up the spots where the little rocks are with detailing solution or car shampoo or whatever and work them out.
cavemanmoore (06-17-2024)
Old 06-16-2024, 09:09 AM
HudsonOH992GTS
HudsonOH992GTS's Avatar
I have gotten those 3-4 times. I use a small metal pick and am able to push them in and move them to the larger openings at the junction of the door, rocker and wing and they come right out.
Old 06-16-2024, 09:20 AM
Bxstr
Bxstr's Avatar
Received 3,105 Likes on 2,124 Posts
Bumper is easier. You can typically flex the bumper enough down and then get a plastic pry tool in there to flush it out. The others ones should still come out with the plastic pry tool, but there may be some light scratching done in the process. Could also try compressed air at an angle, but I feel in general the plastic pry tool is your best bet. Hook tool would be fine if you have a steady hand to not stab the paint.
Old 06-16-2024, 10:26 AM
shrimp money
shrimp money's Avatar
Received 5,193 Likes on 2,069 Posts
Get some fishing line and feed it through the line and behind the rocks. It has a natural curl, so the end will be poking out towards you if you do it right.
Old 06-16-2024, 12:45 PM
jhenson29
jhenson29's Avatar
Received 1,251 Likes on 510 Posts
I just used touch up paint so now I have small rocks in exterior color. Waiting to get them PPF’d. I don’t want rock chips on my rocks.
asuresh8 (06-19-2024)
Old 06-16-2024, 01:55 PM
Icegrill
Icegrill's Avatar
Spray quick detailer and ‘float’ them out. No scratches.
The following 2 users liked this post by Icegrill:
PSPorsche (06-16-2024), tmslc (06-19-2024)
Old 06-16-2024, 09:27 PM
Angryinch
Angryinch's Avatar
Received 1,127 Likes on 670 Posts
I get those on my TTS too, highly annoying. It’s the cup2s they throw rocks like nothing else.
Jeff Whitten (06-16-2024)
Old 06-16-2024, 09:31 PM
aggie57
aggie57's Avatar
Received 2,876 Likes on 1,516 Posts
Most likely already scratched (on the way in) and if you will become worse if you leave them in there. Just open the joint a little using a non-metallic tool and pry them out.
Old 06-16-2024, 10:23 PM
detansinn
detansinn's Avatar
Received 8,145 Likes on 3,010 Posts
I have used compressed air to blow them out the way that they came in.
Old 06-17-2024, 01:34 AM
Icegrill
Icegrill's Avatar
I’m surprised you wouldn’t leave them as an exercise in durability ….
Old 06-17-2024, 09:51 AM
patentguy
patentguy's Avatar
The wheels are shooting rocks into the cracks. I am going to try putting a blob of silicone over the wheel well opening to keep the stones from lodging in the first place.
Old 06-17-2024, 11:42 AM
ipse dixit
ipse dixit's Avatar
Received 11,776 Likes on 5,141 Posts
Fish string.
Use it like you would floss for your teeth.
Old 06-18-2024, 06:24 PM
TheOtherDave
TheOtherDave's Avatar
This is the way.
Old 06-18-2024, 08:18 PM
Res Ips
Res Ips's Avatar
Maybe press fit 2mm vinyl cordage in the panel separation to prevent this from occurring again. It's available in different colors. Body shops use this from time to time to fill gaps that can't be adjusted beyond certain tolerances...just a thought...
Quick Reply: Rocks inside body panels
