I had a recent 2y/20k miles service on my 22 GTS 7MT.
I had nearly 4300 miles, now I have 5k miles.
whats this leak?
I’ll take to dealership soon, but getting your opinions.
Service was over a month ago, will it still be wet.. after this long. I haven’t seen any drops as such in my garage. I just put it up on lift as I took another car out, and that’s when I saw.
Certainly looks like when you had your oil changed ZERO cleanup was done afterwards by the tech. Clean it off with de-greaser or mineral spirits and dry it good and recheck after a week or so. Use caution using Contact Cleaner or Brake Cleaner on the plastic pan/drain plug as it is quite strong.
Just another reason I prefer to do my own oil changes and basic maintenance if I can.
In one month's time, if driven regularly, that oil should look more dried and covered in road grime if just post oil change sloppy clean up. If car is not driven often and frequently, then this could be an active minor seepage due to the drain plug o-ring being pinched or damaged after the last oil change. You have two options; 1) clean it up to see if it stays clean and if not, take it back to the dealer, 2) or take it back to the dealer now who will also probably first cleaning it and then tell you to come back if it's wet again after a few days of normal driving.
These are one-time-use drain plugs. Maybe it needs replacing. The only way you can verify is by cleaning the area and reinspecting after 24-48 hours. You should see some seepage by then if it's happening
Use an old or super cheap disposable Paint Brush, Dawn Dish Detergent and Water. 1.) Wash the area using the Pain Brush and the Dawn Dish Detergent, 2.) Rinse and then wait for it to dry. 3.) Take a picture, 4.) Wait a day or two and take another picture. 5.) Compare the pictures.
