Question re ceramic coating durability
Old May 24, 2024 | 01:59 PM
Hunky's Avatar
Hunky
I know not a single person who is happy with his "Ceramic" job with one guy paid nearly $1,600 and it is very noticeably degraded in a tad over a year. I don't believe he did any of the subsequent tune up applications of whatever which is total BS when this snake oil is hyped as being viable for many years.
I give my vehicles a wipe down with Adams Graphene Detail Spray occaisionally and that yields a finish equal or better than any of the Ceramic jobs I see.
Old May 24, 2024 | 02:00 PM
Tobeit's Avatar
Tobeit
Originally Posted by readydiverone
Hey guys, I had my 911 professionally ceramic coated about a year ago, in early April 2023. I hand wash the car carefully somewhat regularly, probably on average 4/month, maybe more in Spring/Summer months. No one else has ever washed it. Recently, I've noticed that the water doesn't bead as well as it used to; in particular, the sides of the doors get this weird fine bubble coating that then dissipates into kind of a spider web pattern, see photo. It easily rinses off and it's not a big deal, but I guess the ceramic as worn off in those areas. Thanks.
As far as my experience goes also ceramic coating needs to be refreshed at least every year or the surface gets compromised and does not do its job anymore. Also, how quickly that happens depends on what wash soap you use. My shop retreats the car every year for 3 years and then reapplies ceramic from a scratch.
Old May 24, 2024 | 02:10 PM
readydiverone's Avatar
readydiverone
@TUD thanks much, will def try that Wet Coat!!
Old May 24, 2024 | 02:13 PM
RatherJaded's Avatar
RatherJaded
You are welcome. FYI, Gyeon Bathe+ (soap) is good for maintenance washes too.
Old May 24, 2024 | 02:29 PM
reddsektor's Avatar
reddsektor
Enough with the snake oil BS. Quality ceramic coatings last. Period. If they don’t then either your installer did a **** poor job, or used some really cheap stuff, or you didn’t wash/maintain it properly afterwards (not referring to the OP as they clearly are using the right products and method). My car has been coated and going super strong with hydrophobic properties for over 3 years now, came with a 5yr warranty. Daily driver in the harshest conditions. Never once “tuned” it up either.
Old May 24, 2024 | 02:32 PM
readydiverone
@reddsektor thanks, can you share the brand of ceramic you got? It's pretty clear to me I got short changed, want to do better next time. Thanks.
Old May 24, 2024 | 02:50 PM
RatherJaded
Approx four years ago I had a paint correction performed on a European vehicle (not a Porsche) and the below along with Gtechniq EXO were applied via an “accredited detailer” and it was total crap. $2300 flushed. FYI, I know how to properly perform a maintenance wash and I use quality products as well. If something sounds too good to be true then it usually is.
Edit. It also came with a serial numbered registration card and sticker for vehicle.
Old May 24, 2024 | 02:56 PM
reddsektor's Avatar
reddsektor
Its CeramicPro. Even came with an official product registration/warranty card.
Old May 24, 2024 | 03:01 PM
GTSGO!'s Avatar
GTSGO!
My wife has a 3yr Cayenne with a Carpro cQuartz coating. The installer suggested we use Carpro Elixir after each wash and so far, knock on wood, the coating still performs as new. I was originally skeptical of the cost of the coating, but it’s been great and makes upkeep really easy.
I like a bit more gloss on my cars and use other products, but keeping the process above for my wife’s car definitely worked well for the life span (so far) of the coating.
reddsektor's Avatar
reddsektor
Originally Posted by TUD
Approx four years ago I had a paint correction performed on a European vehicle (not a Porsche) and the below along with Gtechniq EXO were applied via an “accredited detailer” and it was total crap. $2300 flushed. FYI, I know how to properly perform a maintenance wash and I use quality products as well. If something sounds to good to be true then it usually is.
sorry to hear that was your case. But there’s many more successful testimonials on ceramic than there aren’t. Nothing really too good to be true about it for most. Mines also only costed $800 with labor and prep.
Old May 24, 2024 | 03:55 PM
ENCT's Avatar
ENCT
I have had many different coatings and have decided Ceramic Pro is the best. Have it on 3 vehicles and it lasts. I won't have anything else put on our cars.
Old May 24, 2024 | 04:02 PM
readydiverone
Can one buy Ceramic Pro and apply oneself, or is it only pro applicators?
Old May 24, 2024 | 04:14 PM
shrimp money's Avatar
shrimp money
Is it because the shop applying it didn't make a video of them dispensing the serum onto an applicator like they're in an OR?
Old May 24, 2024 | 04:23 PM
Shogunade's Avatar
Shogunade
Originally Posted by woobiee
That looks premature after one year. My 'unprofessional' coating is in year two and still holding quite strong.
Which coating did you use? I have cquartz UK 3.0 and gyeon mohs. Leaning towards cquartz.
Old May 24, 2024 | 05:27 PM
Orca911's Avatar
Orca911
I had a detail shop do a car and the coating was awesome. I let the dealer do my last car and I am not so sure.
I do know that using harsher cleaners (like Mother R3) will 100% take of the ceramic coating. It (R3)is magic for taking of tire rubber - but its also magic for removing the ceramic coating.
I am in the camp now if you are going to do it - get it done REALLY well with paint correction - or pass.
Not sure its really needed.
