Dead Battery Front Trunk--Again/Follow Up
I'm sure tow truck drivers carry jumper cables.
As i said before though, the jump pack would need to be in the cabin to be useful. Where I'm from that's just too much of a theft liability for me. I don't want to get a window broken because someone wants my jump pack (or what ever they think it might be).
Received 3,965 Likes
This is easy.
Carry this (or similar) in the back seat, its not very big and has a tremendous amount of power. Remember to charge it up once or twice a year. It will pop your front bonnet when used on the fuse-box pull out, and jump your car, either conventional or Li-Ion Battery.
I use this Noco unit, because I have a diesel truck as well - you don't need this much power, but its nice to have.
Premium Sponsor
CurryPuff (05-15-2024)
Premium Sponsor
No because our Harnesses have a built in diode to protect from back charge to your Jump Starter for safety... Lithium in the Jump Starters charges via a USB port and does not match a cars charging system, so we have this for safety. But in reality its quite easy to attach both to the terminals at the battery posts. But please note DO NOT TRY TO TAKE OFF YOUR NUT on your batterys post in Porsches. Just loosen it and cut the Ring terminal if its a complete circle, then slide it behind the nut and tighten..
Premium Sponsor
Lastly our MICRO-START Jump Starter are literally HALF the size of the NOCO unit and offer MORE power, so they fit in you glove boxes easily. Yes we know NOCO is a bestseller on Amazon and they are an Amazon type company, we are not. But our product beat them on every performance metric, charging speed and features. Things like USB PD100 watt charging, much bigger battery inside a much smaller case format, detachable clamps on our most powerful units for ultra compact stowing. Check out the MICRO-STARTs here>>> https://antigravitybatteries.com/pro.../micro-starts/
Scott P (05-16-2024)
Are the cables on your micro-start device long enough to reach the two attach points for the frunk pop operation? Or do you need an extension cable for the ground?
nyca (05-16-2024)
Premium Sponsor
And if you have no voltage reading, meaning battery very dead, our MICRO-STARTs also have a Bypass so you can get live voltage to the clamps and bypass the protections, so you can power your switch. The protections normally don't allow voltage to the clamps if they do not sense voltage from a battery, this is a safety measure so that you don't get sparks or have live voltage at the clamps that could short circuit something. So we made a bypass because sometimes the batteries are so dead they are not reading voltage or you need to apply power to some device.
I ordered your XP-1 Gen2 unit now.
It has probably been mentioned already, but isn't this a stupid design flaw by Porsche? How hard would it have been to have an emergency cable release like every other car in history? I say class action law suit.
nyca (05-17-2024)
@Antigravity I am interested in having a power source to pop the hood if necessary. It's for my 992 T (AGM) daily, but since I work from home and travel, there are periods where it sits.
So - I'd like to have a power source and a tender, with the connection peaking out from the passenger side hood. What product(s) do I select?
Any risk to leaving the jump pack in a hot car? Had a cheap solar USB brick nearly explode on my Bronco dash (swelled up like a mellon!) from sitting in the sun/heat, so don't want to introduce any possible fire hazzard (and have since tossed the cheap solar USB bricks at the battery recyclers!)
Thanks!
Thanks!
nyca (05-17-2024)
Premium Sponsor
@Antigravity How long will the charge last in glovebox?
Also note our MICRO-START charge and offer from PD100w Charging (very fast and can power Apple and PC laptops... for example the XP20 models. other charge at PD 30 to PD60 w. Not matter the brand you get you should look for that also because it offer the faster charging that modern electronics require. Ours XP-20 can also be recharge fully in 1 hour and its 24,000mah so that is ultra fast recharging... but you have to use it special 100w charger that comes with it, or something compatible.
Biohazard (05-20-2024)
Premium Sponsor
Thanks!
Thanks!
- Here what you would want to do if you not driving the car and out traveling... if you need something to cover a month or two.. Don't try to use Battery Charger/Tender. The reason for this is they run of 120v, and whille you could attach a Battery Charger/Tender to an inverter you are losing alot of energy in the conversion and it draws alot of energy when in standby and doing a low power maintenance even. You could also use a Powerstation to power your battery tender but again the conversion is going to suck energy as well as the inverter staying on draws alot of energy in the Powerstations. So you could run out of energy oretty fast. If you are going away on a trip, and don't mind having and extra Car Battery in your frunk or a table next to your car, just get another cheap Car battery with like 500Amp Hours... which is a small one, and connect it in parallel to your existing battery in your car. You can just use a small set of Alligator clips using like 14guage wire or some aligator ended test leads since you will NOT be starting the car, or running the car like this. Your essentially making a battery bank to get more capacity, and you won't have any extra power drawing because your not trying to power a 120v device. Your simply making your battery larger, and your draw will only be from your car. You could make it super quick and easy For example you could have a battery tender lead like the one for charging, them also get the Battery Tender leads with Alligator clips that plugs into your Battery Tender leads coming from your batttery (make sure polarity stay correct). then just clip onto the extra battery you put in your frunk when traveling.
As far as a hot car and Jump Starter.... if you have the Jump Starter under your seat or in the glove box it will be fine. ON the dash is really bad beacuse temps can get over 190 degrees. The type of lithium chemistry used in these Jump Starters is more prone to heat damage and even swelling, and worst case scenario fire... compared to the type used for Automotive Starter Batteries because they are a super energy dense chemistry. So high heat can shorten their life but in general they will not be a fire damage unless they are put into a very extreme temperature. Our Jumpstarters come with a padded case that acts as insulation to a degree, but under the seat and away from direct heat and sunlight nailing them is OK for them.
I also forgot to mention you can use a solar battery charger and a small solar panel about 60w minimum and keep it charged if you have some sun, we make those also.
