GTS Turbo Swap for 2024 Carerra T
USA press release (does not specify transmission):
https://newsroom.porsche.com/en_US/2...ere-30090.html
Note the language: The T variant also utilizes the mechanical limited slip differential with Porsche Torque Vectoring (PTV) that is standard on the 911 Carrera S and is not available for the 911 Carrera.
Australia (specifies 7MT only):
https://newsroom.porsche.com/en_AU/2...hts-32961.html
Note the language:The 911 Carrera T is fitted with Porsche Torque Vectoring (PTV) and a mechanical rear differential lock when specified with the seven-speed manual transmission.
Could it differ by USA v. ROW?
Also, the US press release clearly states PTV on the T is the same as on the Carrera S.
Thanks everyone! Decided to move forward and placed my order last night. Today, will be receiving a set of Litespeed RS5RR Mag+ wheels that will be fitted with 255/315 PS4s to help with grip. Will post impressions/pics once everything is done.
thx,
bc
thx,
bc
The following 4 users liked this post by BarryC:
you're going to love it!
Essentially a T gives you and S chassis, and a manual transmission option, with the base engine.
I have a 2024 T. All T’s regardless of transmission are equipped with SPASM and PTV. Only the manual has a mechanical limited slip differential. The PDK comes with the PTV+ version of PTV instead of the limited slip diff. PTV is identical on the S and T when equipped with the same transmissions. SPASM is optional on the S.
I couldn't find clarification anywhere, the verbiage was confusing on what I did find. So.....a PDK T does indeed have Porsche Torque Vectoring? I know the PDK T has PASM and electronic LSD.
Blueblazer (05-15-2024)
With GTS level power it’s not an issue. I’m curious how traction is when we get up to S/GTS Stage 1 (545whp/545wtq) and higher power levels. The stock PS4S are good but wonder how much need there will be for Cup 2’s or similar tire on the street. Especially for me here in Florida where it downpours without warning.
Yes, a PDK T has what Porsche calls PTV+. PTV+ is normal PTV (which brakes individual wheels to vector torque) as well as an e-diff capability to regulate axel speeds on both sides of the car independently (essentially replicating a limited slip diff). The manual T has PTV (again, which brakes individual wheels), but relies on an actual mechanical limited slip diff to regulate axel speeds. Two ways of accomplishing the same thing. FWIW, Porsche does not claim either way is superior to the other performance wise.
mattchow (05-15-2024)
