Frunk open when using CTEK
Old 02-23-2024, 09:35 PM
jmrichards
jmrichards's Avatar
Default Frunk open when using CTEK
Is your frunk slightly cracked open when charging in the garage, or does the lid actually close? If open, does a frunk light drain the battery?
Old 02-23-2024, 09:41 PM
Spatia
Spatia's Avatar
I feed my ctek cable out the top of the hood near the hinge by the windshield. Close up the hood.
The following 5 users liked this post by Spatia:
Motorin Mark (02-24-2024), shrimp money (02-23-2024), TimD (02-23-2024), vasmir (02-23-2024), vg247 (02-24-2024)
Kevin33
Kevin33's Avatar
Lid closed, wires out the top by windshield. Not sure why you’d leave it open; not sure about the light.
Old 02-23-2024, 09:57 PM
jmrichards
jmrichards's Avatar
Doesn't this mean the end of the battery connector is exposed to the elements?
Old 02-23-2024, 10:02 PM
jmrichards
jmrichards's Avatar
See Harry at 6 minutes:
PG5768 (02-23-2024)
Old 02-23-2024, 10:05 PM
German1967
German1967's Avatar
I leave it cracked open when on the CTEK. The frunk light shuts off after a while.
The following 6 users liked this post by German1967:
alin2 (02-24-2024), doug_999 (02-24-2024), jmrichards (02-23-2024), mikey94025 (02-26-2024), Pad Bender (02-23-2024), STIGETTE (02-24-2024) and 1 others liked this post. (Show less...)
Old 02-23-2024, 11:04 PM
Pad Bender
Pad Bender's Avatar
Received 1,260 Likes on 638 Posts
After having to jump that dam fuse box...i leave the frunk cracked. whole point of a trick charger is to prevent drain anyway.
Car will still lock anyways and I keep it under cover as I have no space in my garage.
Old 02-23-2024, 11:35 PM
vasmir
vasmir's Avatar
+1
TimD (02-24-2024)
Old 02-24-2024, 02:36 AM
Spatia
Spatia's Avatar
No - I have the permanently mounted clips on the battery with the 12 inch lead. And then I add one of CTEKs 8 ft extension onto that to the charger. The lead stays under the hood and the cover for the battery. When I unplug it - it’s all under the battery cover.
Jeff Whitten (02-24-2024)
Old 02-24-2024, 03:39 AM
Cokerrat
Cokerrat's Avatar
It comes with a tethered “cap” to protect the open end of the connection when not connected to an extension cable. Routing out the top of the frunk is a slick set up.
Old 02-24-2024, 04:59 AM
M3Inline6
M3Inline6's Avatar
Received 1,426 Likes on 778 Posts
Like many others, frunk fully closed with the connector coming out near the windshield. I had to jump the car using the damn fuse box and it’s a pain in the ***. Thanks what I get for not driving the car for 6 months and not having the car on a tender. Eeps! Now she’s on a tender right along with the V4.
Old 02-24-2024, 11:41 AM
doug_999
doug_999's Avatar
Frunk open - well, slightly closed. Don't love the Ctek connector showing up by the windshield and as you can see above, I don't love the cord hanging down the side of my car. So frunk - one click down, wire out front.
Old 02-24-2024, 12:58 PM
KenTO
KenTO's Avatar
I leave the frunk slightly open in case the battery dies, and have the wires come out the front of the frunk. As others have stated, it is very difficult to open the hood if closed in that situation, see other posts on this matter. Essentially if the battery dies with the frunk closed, you have to use the key blade to open the door, open the fuse box inside, and connect a charge to the frunk fuse to power it on to open the frunk. Add to that that the charging of the battery can be very finicky (as I have had to reset mine many times due to the Porsche charger shutting off by itself, and it is connected directly to the battery) better to leave frunk open.
https://rennlist.com/forums/992/1238...nk-help-2.html
Old 02-24-2024, 02:01 PM
Antigravity
Premium Sponsor
Antigravity's Avatar
As an FYI Antigravity Batteries makes a simple Wire Harness (which we call the "Clampless Harness") that allows you to use a mini Lithium Jump Start to Power your system to open the frunk OR Jump Start your Car when the battery dead. Its much simpler than going into the Fuse Box and takes literally seconds. Also takes about 2 minutes to install.
When needed you just plug-in the jump starter to the wire harness that you route to the edge of the windshield, then pop the frunk via your Porsche keyfob or switch at the rocker panel area, or if you just want to jump start the car you just put in your key and start your car. Our Wire Harness also comes with a Protective cover you cover the end from the elements. The benefit of this over going to the Fuse area is that you are actually powering the entire system on the Car so you get the full current to the Switch so it pops the frunk easily.
WE make them for our MICRO-START Jump Starters but they also fit several other brands of Jump Starters also that have the standard type plugs. It does not fit the Jump Starters with proprietary plugs like NOCO and some others.
https://antigravitybatteries.com/pro...s-msa10c-long/
Old 02-24-2024, 02:02 PM
alin2
alin2's Avatar
As with others, I leave the frunk slightly open when attaching the CTEK battery tender. The frunk light shuts off after a few minutes.
Quick Reply: Frunk open when using CTEK
