MY 2022 Rattles
MY 2022 Rattles
I've read through a few different threads here on rattles. My car has the extended fuel tank installed -- but still notice the rattling/creaking even when the tank is full. It sounds like it's coming from the center of the dash near the Chrono. Have a couple of videos attached. Any ideas or thoughts on what it could be? It's more pronounced on rough roads, but I'm pretty sure I've noticed it on the highway at speed as well.
The frequency doesn't seem to match what would be caused by a road vibration. Is the fan in the HVAC running during this video? It almost sounds like the HVAC fan is chattering or hitting something.
Sorta sounds like a rattle I have and figured I'd share - If you have a sunroof, try cracking it (barely touch the button) to the point it could still be considered closed. I have a rattle in my 23 GTS that if I do this the rattle disappears. I've just learned to deal with it by employing this solution. As I said, sunroof is basically still closed. Might not be your issue, but sometimes sounds play tricks on your location perception.
Note: I've tried the treating the seals and such, but this offered no resolution.
huh...interesting. I'll give that a shot -- thank you for the suggestion!
My 2022 GTS has an ongoing sunroof squeak (more like a soft crunching noise).
No dealership seems to able to fix it. Doesn't matter if the sunroof is closed or partially/fully tilted.
I doubt I'll order a glass sunroof again on my next 911.
My gts had the same problem. My dealer in ct seemed aware of this common problem. Was able to fix it. I believe it is related to rubber seals around the sunroof. Try another dealer if near you
Well if its the sunroof seal, try some Gummi Pflege
Tried the sunroof trick and turning HVAC off -- still have the rattle and creaking. Will take it to the dealer in a couple of weeks, hopefully they can get to the bottom of it.
please keep us posted, I have the same rattle, have left my car twice, each time for 7-8 days, they have taken down my gas tank to see if it was from there or left front speaker grill? Nothing worked so I just turn in the music and try to ignore. If you find the fix, please let us know. Thanks
https://rennlist.com/forums/992/1347...l#post19279266
nyca (02-17-2024)
My ‘22 GTS Cab’s dash rattled like crazy right from delivery. The dealer made a couple attempts at a fix and at best subdued it slightly. Eventually the rattle disappeared at about 3,000 miles. The service tech at our local dealer, purchase dealer is in next state, told me the settling in usually takes care of the rattle issues. I had heard that as well from another PCA member. Best of luck with your’s.
I had a rattle on the passenger side of the car that started to annoy me enough that I tried to find the cause myself. It actually sounded like something rolling around in the door bin. I found nothing in the bin, but I did notice the passenger seatbelt buckle with the metal part against the hard plastic of the 18 way seats. I buckled the belt, and sure enough that eliminated the rattle. The buckle was hitting the hard plastic.
I didn’t listen to the sound files posted by the OP, so this probably isn’t the same issue.
TuvaD (02-18-2024)
