HELP!New 992 engine noise!(youtube video with sound)
#31
992Carreras ,When rpm 1500-1700,Lightly press the accelerator,can hear this snoring sound very clearly,please watch my YouTube video here https://youtu.be/KSnCmatyJpU?si=f-HEFW4W1ueqqQ1x. This drives me crazy,my dealer can't solve it. I drive around ten 992 in my dealer and found all 992 have this noise but noise from new 992 is louder than second hand 992. Dose this sounds right?
Good luck!
Mel
#32
Hi .... I have a brand new 2024 911 4S, took delivery a couple of weeks ago. I have "Exactly" the same problem as you have shown in the video. Thank you so much for posting that video! I have had four 4S's in the past, 3 of them 992's, and none of them had this problem. The dealership is telling me wait for another new vehicle to to come in, and they will see if they can reproduce the same problem. Well... that could take many weeks due to the supply chain shortage. They mentioned that Porsche will probably come out with a software fix for this..... well, good luck waiting for that!! So far, no one has answers as to specifically what the problem and the fix is.
Good luck!
Mel
Good luck!
Mel
#33
Yse,I found almost all new 992 have this problem after i drave 10+ 992. Unfortunately,the noise of my 992s is the loudest.
#34
Mine is Manual and I have had this since the day I drove out of the dealer in July was 15 miles on the car. Dealer acknowledged that this is not normal as the sound occurs whether the car is engaged in the transmission or in neutral over bumps. At this point just drive it but file a case w Porsche. These parts (engine mounts, if they are in fact the fix) are globally unavailable. My car has been in the shop for 4 weeks. Parts still need to be produced. I am taking it back tomorrow and waiting for the parts to be available before I try again. Not my dealer’s fault. I also called 1 800 Porsche and filed a case.
#35
At this point just drive it but file a case w Porsche. These parts (engine mounts, if they are in fact the fix) are globally unavailable. My car has been in the shop for 4 weeks. Parts still need to be produced. I am taking it back tomorrow and waiting for the parts to be available before I try again. Not my dealer’s fault. I also called 1 800 Porsche and file a case.
#36
Hi folks,
I was reading carefully last days this thread and I was listening into my 992 (April/2023) carefully same last days. Did since the post about 500 miles. I tried to reproduce or hear on mine with normal mode, sport, sport plus (cold/hot engine) and I tried basically every combination with exhaust valve open/close etc.
I have to say I am very sensitive on any abnormal noise and I can confirm definitely mine isn’t having that noise at all.
I am very sorry for you. I would definitely insist to my dealership to fix this what you show in your video.
good luck 🍀
good luck 🍀
Schwarz992C4S (12-13-2023)
#38
I have a 992 Turbo 2021. My car started to make this cricket noise at 3100km and I m very disapointed with it. Looks like Im using a defective car . The dealer told me thats normal, but when I bought it and ultil 3100km this cricket noise was not there, so, I dont believe its normal. Normal is not have this cricket noise.
The ideal is to listen or film in a quiet place and inside a garage or with side walls so as not to disperse the sound.
If you have same problem, you have to complain not to the dealership, but directly to the manufacturer !
I sent email to : customer.relations@porsche.de
Everyone should send an email to the manufacturer to see if they can issue a recall or at least provide a solution.
Please, watch the video below.
#39
Hi folks,
good luck 🍀
good luck 🍀
#40
Hi folks,
good luck 🍀
good luck 🍀
#42
just re watched the video on earphones and can hear that thumping noise now, if that’s what the noise in question is. Never heard it in my base 992 or I simply never noticed it
#43
Hi friends,
#45
I have this problem too. The same metallic rattling noise below 2k rpm and coming from the rear.
Its a 992 "base" model coupe bought new from official Porsche Dealership and I heard this from the day one.
(The day one was a week ago).
That noises disappears with cold engine and appears after a 10/15 minutes ride.
have you solved this? or, at least, know where does it come from?
thanks
thanks
