Sunroof Question - MY23
Wondering how the glass tilt function is supposed to work?
I have a 2023 4S with the glass sunroof option. When I press the tilt button, it does just that. However when I press the button a second time, presumably to close it, it does not close. Instead the glass quickly moves to the closed position and reopens to the tilt position. I’ve resorted to opening the sunroof completely in order to close it from the tilt position. Is this how yours works or am I doing something wrong?
I had a 2020 4S and remember being able to tilt the sunroof and close it with the same button, just not sure if something changed for MY23 models.
Thanks in advance!
Thanks in advance!
The following 2 users liked this post by PBoxS986:
reyesanders (10-23-2023),
Scott P (10-23-2023)
^^^ This. I have the glass sunroof option and I've never seen it act like yours thankfully.
https://rennlist.com/forums/992/1200...own-close.html
detansinn (10-23-2023)
This was the first issue I had with the car. The root cause of this was due to some resistance when closing. I assume some moisture that made the seal around the glass sticky. The dealer ended up putting some additional lube around the seal and my issue went away. Good luck with getting your issue resolved.
