Nokian Hakka R5 EV
Old Oct 16, 2023 | 05:26 PM
968boy's Avatar
968boy
Default Nokian Hakka R5 EV
Has anyone run these on the 992? They come in 235/35/20 and 295/30/21 which should be good for the OEM winter wheels.
PA5's are great on a cold dry road, but being a performance winter tire, they have lacked a bit in the snow...looking for more bite in bad weather like I had with Sottozero 3's on my 991.
Thanks!
Old Oct 16, 2023 | 06:01 PM
Scott P's Avatar
Scott P
I've never had them but have always heard great things about Nokian tires.
Old Oct 16, 2023 | 06:04 PM
Jarm's Avatar
Jarm
Just cross posting from the other thread:
I hadn't considered the R5 EV, that's not a bad idea. According to tire review (appears sourced by Nokian directly), the R5 EV "[adds] a layer of acoustic foam on the inner liner of the tire" and "comes with a stronger structure and reinforced tread profile with an additional amount of rubber to withstand high torque and high wheel loads". ... it looks to be a slightly different tire, but ultimately the same tread pattern. And hey, it being meant for the increased torque of an EV, probably isn't necessarily a bad thing for our cars.
Old Oct 16, 2023 | 07:21 PM
doug_999's Avatar
doug_999
Thanks!
A performance winter tire prioritizes dry/wet cold traction over deep snow traction. The Sottozeros are not rated better than the PA4s, so I doubt they are better than the PA5s... something tells me the 991 just did better in the snow than the 992 (I have the PZero Winters and I'm not impressed either).
https://www.tirerack.com/tires/tests...y.jsp?ttid=181
The Nokian are snow tires and while Nokian has come a LONG way in the dry/wet cold - they won't out perform the PA5 there. But they will crush it in the snow.
Just my thinking
