What is the recommended solution for winter tires. Not planning on going out in the snow and buying new OEM rims is too expensive. Tried looking for a used set but no luck. Are there any aftermarket rims that you can recommend or do most just switch the rubber on existing rims?
I have a used set of winter tires for sale. 245/20 fronts and 305/21 rear Michelin Alpin 5 NA0 rated. They won't fit the GT3 wheels but the GTS should use these sizes. Not sure where you are but I am in the OKC area.
How much are you looking to spend on wheels? The cheapest I have seen are these, not sure about quality. For quality center lock rims you are probably looking at $2000+ a wheel.
How much are you looking to spend on wheels? The cheapest I have seen are these, not sure about quality. For quality center lock rims you are probably looking at $1000+ a wheel.
