Removing rev limiter on 7MT models
As some of you may know, on the manual transmission models, you can’t launch and or spin wheels because the standing idle is limited to 3500 RPMs.
Anyone know how to get rid of this limitation? I’m assuming doing so would void warranty so considering doing it at conclusion thereof.
Thanks.
Thanks.
I have never had one issue in four water-cooled cars. I have had to fix a few air-cooled cars due to former owner negligence.
The MT's are not designed to be dragsters.The extra RPM and corresponding stored energy could easily break parts of the drivetrain. With a PDK or Automatic Porsche can electronically manage the allowable loads and consequently push closer to the mechanical limits of the drivetrain.
Doing the same with the MT, there is no control except your calibrated left leg, and all bets are off. Also, be careful of stacking load factors like sticky tires, stronger clutch, hot pavement, tunes, etc. They all add to the drivetrain load and eventually you will find the weak (and usually expensive) link. Good luck.
Wasn't there a thread about people breaking their rear axles doing 0-60 runs a little while back? Might've been in the 992 GT cars sub-forum. But if anything, I would think turbocharged engines, with their greater low-end torque, are even more problematic than the NA GT cars.
