PDCC in 992 Gts
Old 07-19-2023, 08:35 PM
  #31
Fullyield
Fullyield's Avatar
Received 1,502 Likes on 937 Posts
If you are required to have RAS when you order PDCC as stated in Post 11, that means you will have a lithium battery in the US. You might also want to read the lithium battery threads on here before you make a decision. Your car and your $$ so it’s up to you……just research it and make informed and educated decisions. Get what YOU want, not what a bunch of guys on the internet who you don’t know say they want.
AeroSmith997 (07-24-2023)
Old 07-20-2023, 01:10 AM
  #32
ipse dixit
ipse dixit's Avatar
Received 11,772 Likes on 5,138 Posts
Originally Posted by Throttle Lift
But What about the daily comfort aspect? Not that a "regular" 992 is harsh at all but does it make a NOTICEABLE difference on the street?
No
Old 07-20-2023, 08:56 AM
  #33
CanAutM3
CanAutM3's Avatar
Received 1,328 Likes on 621 Posts
No
Not sure why you’d say that. I had the opportunity to drive my buddies S-PASM turbo-S that has PDCC as standard back to back with my S-PASM turbo that is specced without PDCC, and the ride did feel more comfortable in the turbo-S, better absorbing one side road imperfections. I did not get to drive it on track though, so I cannot give at-the-limit handling impressions. Since the GTS shares the same S-PASM setup as the turbo-series, I have to assume PDCC will make the ride more compliant on the GTS as well.
Old 07-20-2023, 11:45 AM
  #34
ipse dixit
ipse dixit's Avatar
More lateral stability (on the Y axis) does not mean more comfort.
At least not in my book.
jlegelis (07-20-2023)
Old 07-20-2023, 01:16 PM
  #35
CanAutM3
CanAutM3's Avatar
A stiffer sway bar will induce a sharper jolt on the roll axis when hitting a bump on only one side of the car. A softer swaybar will soften than jolt and improve ride comfort. That is the whole point of PDCC.
Billy Bluejay (07-22-2023)
Old 07-20-2023, 02:07 PM
  #36
jlegelis
jlegelis's Avatar
To the @Siso78 , have you actually *driven* a GTS? Many here (including myself) would suggest that if you are concerned about 'comfort' than a GTS is the wrong place to start.... coming from a Macan T / Panamera even a base 992 will be a game changer and may be 'more car' than you want. At least one other poster recently expressed frustration at the lack of 992 GTS utility in city driving, which is problematic discussion for a hosts of reasons.
Old 07-20-2023, 03:04 PM
  #37
AlfaM5
AlfaM5's Avatar
I don't know about RAS and PDCC but my feeling is a 911 doesn't need any of these things. On my GTS I was interested in keeping it light so I got no options. I wasn't sold on the Lightweight package though if I could do it again I'd probably get the carbon ceramic brakes. They're amazing. Not that anything is wrong with the steel brakes but the current GTS is really dialed as noted above and the reduced weight and different feel of the carbon brakes would have been the cherry on top.
catdog2 (07-21-2023)
Old 07-20-2023, 03:05 PM
  #38
CanAutM3
CanAutM3's Avatar
I guess it all depends what one is after. PDCC narrows the required compromise between handling and comfort, the drawback being higher cost, weight and a more disconnected feel at the limit. So for one that seeks the higher performance potential of a GTS while alleviating some of inherent comfort compromise, PDCC can be a compelling option.
AlfaM5 (07-20-2023)
Old 07-20-2023, 06:59 PM
  #39
ipse dixit
ipse dixit's Avatar
I don't disagree with you on how PDCC functions, just that the effect of PDCC on driving dynamics is not necessarily synonymous with ride comfort.
There are some here on Rennlist, and maybe even in real life, that experience car sickness in a 911 equipped with PDCC.
Old 07-20-2023, 07:04 PM
  #40
CanAutM3
CanAutM3's Avatar
That is a contradiction.
And that is funny !
Old 07-20-2023, 08:27 PM
  #41
AlfaM5
AlfaM5's Avatar
I've driven Mercedes AMG cars with this technology and I didn't like it. Feels artificial. Not sure how it functions on the 911. Either way, I don't think these technologies are needed and perhaps even detract from these cars.
Old 07-21-2023, 09:26 AM
  #42
Fullyield
Fullyield's Avatar
Not sure why you’d say that. .
Maybe because he does not have ownership bias which is common and prevalent on RL?
Old 07-21-2023, 10:37 AM
  #43
CanAutM3
CanAutM3's Avatar
Ownership bias or not, saying that PDCC does not improve ride comfort is a false statement.
vic55 (07-22-2023)
Old 07-21-2023, 03:38 PM
  #44
dgoldenz
dgoldenz's Avatar
I have both a 992 GTS with PDCC/RAS and a 991.1 GTS without PDCC and there is a very noticeable difference. The 991 still has great handling but the cornering on the 992 with the PDCC/RAS combo is insanely good. I'd say it's worth the money personally.
The following 2 users liked this post by dgoldenz:
dhirm5 (07-23-2023), Grimz (09-05-2023)
Old 07-21-2023, 06:00 PM
  #45
OMTarga4S
OMTarga4S's Avatar
Do you have a hardtop or a sunroof?
Quick Reply: PDCC in 992 Gts
