Squeaks and rattles
Yes, I know, there are a million posts on this topic, blah blah blah. But they're mostly old, seem to cover different issues (like blown speakers), and often aren't terribly definitive. So here we go again.
Mine has a squeak somewhere on the passenger door, and an outright rattle at higher speeds in the rear passenger area. Bose speakers. I've read the front squeak can be fixed with foam once they tear the door apart. The rear might be a tweeter rattling around in its bracket. Or something else entirely. Are people still having these same issues with new 911s? Bose related? Are there technical bulletins?
Ive had a 2020 C2 and a 2021 C2S, both had slight rattles coming from either the passenger door or the drivers door. Dealer tried and tried but could not fix it, so I decided to go at it myself.
The ONLY thing that worked for me on both cars was to remove the door panels, and inside you will see plenty of torx screws holding various pieces of the panel together.
Back every torx screw out 1/2 to 3/4 of the way out and spray a dry lubricant on each one, then tighten them back down.
I did not need to use anything other than this to eliminate the rattles in my door panels. YMMV.
The following 4 users liked this post by Drew_W:
