2022 GTS manual. Same error. 3 different times within the first 1000 miles. Fuel level was really low all 3 times. When I realized that, I have been re-fueling with around 1/4 tank / 100 miles to empty. Haven't had the error for the last 4k miles regardless of driving style and speeds. It seemed to be low fuel related for me.
I am having same issue "reduced engine power" when accelerating on highway. 2021 C4S, Brought it to the dealer and says it is bad injector on cylinder. Dealer says they need to drop the engine to change it. "Sounds like a lot of work and tearing my "baby" apart for a slightly annoying code that only appears once in a while. 4000 miles on the car. I am leaning towards not replacing it and hopefully it is bad gas or moisture in tank or a sticky injector that will free up over time. Has anyone changed a injector in a 992?
Started getting this message around 19k miles on my 20 S. Same experience at first with message going away on restart and not coming back for some time. Then it began to recur about once a week with rough running so I had to pull over, shut down and restart. Dealer traced to bad injector on number 3 I think. Anyway was hardest one to access. Don't know how extensive teardown was, but they did have to do a wheel alignment. Been perfect since. Underside of car looks untouched.
**** ton of issues with 992s. Do some searches and youll see. Moreover, most aren't even on Rennlist so you don't know what's really going on. This is just a sampling.
There really aren't. Do you even have one or are you just basing this on a few rennlist threads? Mine has been rock solid, just like my 991.2. My 992 is a manual.
Thanks, Eagle1960, Yes, the dealer narrowed it down to the number 1 injector so i had them replace it. They said they would need it for 4 days to do the repair. They had it done in two days. I'm wondering it they really had to drop the engine of that is worst case scenario for any injector. Maybe the number six injector is accessible by removing the rear bumper and everything else back there. They sent photos when it was apart, and it does not look like the engine is dropped (what does everybody think). Anyhow the car seems to run stronger than ever and no codes!!
