Getting Engine Error Over 125MpH
Old 07-02-2023, 02:21 PM
MattBauer
MattBauer's Avatar
MY21, C2S, 13k miles, all canyon/fun, no issues except Bose speaker rattle. Seldom use the entertainment system. Do oil every 5k, flush brakes at 10k. On third set rears, second set fronts. Brake pad slap due in a couple thousand, pads at 4-5 mil remaining, rotors are halfway, but worn pretty smooth, 1 mill remains. Rears a bit more worn than front as expected. Stock brakes are very decent on the 992 except for track duty. Car has been reliable, not exactly been nice to it either. Had a few squeaks that went away on their own after getting past the first few k of the “brake in” phase. Don’t necessarily agree the car is a defect machine. Sure it feels that way if you have an issue. Happy customers don’t complain in the numbers disgruntled ones do. No comment is a good comment.
The following 2 users liked this post by MattBauer:
jlegelis (07-02-2023), SAlexander (07-02-2023)
Old 07-02-2023, 02:41 PM
alin2
alin2's Avatar
I hope the OP gets his issues sorted and resolved ASAP.
It's impossible to assess the frequency of 992 issues by reading an Internet forum due to clear confounding sampling issues.
The only thing we can accurately assess is that there ARE problems that arise: LiFePO4 battery issues, misfires, etc, not how frequent they're arising amongst all 992s.
The following 2 users liked this post by alin2:
eagle1960 (07-02-2023), jlegelis (07-02-2023)
Old 07-02-2023, 03:01 PM
360MVA
360MVA's Avatar
Manual or pdk?
Old 07-02-2023, 03:48 PM
Shogunade
Shogunade's Avatar
Received 1,880 Likes on 1,056 Posts
Originally Posted by 4 Rings
I had similar issue and was a gas issue.
i think basically the car realized I was consuming more fuel than was a safe level. At those speeds you’re probably WOT or close to it.
fuel the car up and go out and I’m sure that’s it
Hmmm. Those speeds can be reached and maintained not going over 4k.
Old 07-02-2023, 04:18 PM
.2PDK
.2PDK's Avatar
Received 1,243 Likes on 751 Posts
Originally Posted by 360MVA
**** ton of issues with 992s. Do some searches and youll see. Moreover, most aren't even on Rennlist so you don't know what's really going on. This is just a sampling.
Why are these cars such disasters?
Old 07-02-2023, 04:26 PM
teknikk7
teknikk7's Avatar
Car had gas. Not sure how this could be a fuel issue or injector, error states ACC. Isn’t that’s the cruise control?
Needless to say, interesting thread this has turned out to be…
Old 07-02-2023, 04:53 PM
360MVA
360MVA's Avatar
I don't believe Porsche is ready for all this tech. I had an early Taycan Turbo S and it was also a disaster. I got rid of it after a few weeks and now this. I also have a Cayenne Rurbo GT coming and I'm concerned it will have issues as well.
Old 07-02-2023, 05:34 PM
tmslc
tmslc's Avatar
I haven't had any. in fact of the three generations I have owned the 992 is by far the best put together.
Old 07-02-2023, 08:19 PM
360MVA
360MVA's Avatar
manual or pdk?
Old 07-02-2023, 08:21 PM
tmslc
tmslc's Avatar
manual or pdk?
my 992 is pdk.
my 991 was also pdk and i couldn’t wait to get rid of that once i drove a 992.
my 997 was manual and i do miss that.
Old 07-02-2023, 08:25 PM
360MVA
360MVA's Avatar
my 992 is pdk.
It seems the manuals are the cars with the most issues which explains why you haven't experienced any problems. I will say I had two 991.2 GT3 manuals and non issues whatsoever. The 992 is a disaster so far.
Old 09-09-2023, 01:35 PM
Razzou
Razzou's Avatar
I have a 2021 TTS. I had the same message: Engine control error... only a few times a few months ago at any speeds. It will go away when I restart the car. My tech told me it could be from fuel. No messages in the last 6 months. Good luck!
Old 09-09-2023, 02:13 PM
readydiverone
readydiverone's Avatar
Just had my 2022 C2S 7MT cab throw that code. Corrected to normal 15 seconds later while still driving, ie, didn't stop restart car. Hope it doesn't come back.
Old 09-17-2023, 01:40 PM
essex992
2nd Gear
essex992's Avatar
I am having same issue "reduced engine power" when accelerating on highway. 2021 C4S, Brought it to the dealer and says it is bad injector on cylinder. Dealer says they need to drop the engine to change it. "Sounds like a lot of work and tearing my "baby" apart for a slightly annoying code that only appears once in a while. 4000 miles on the car. I am leaning towards not replacing it and hopefully it is bad gas or moisture in tank or a sticky injector that will free up over time. Has anyone changed a injector in a 992?
Old 09-17-2023, 03:26 PM
4 Rings
4 Rings's Avatar
Fuel level has been my issue both times.
Quick Reply: Getting Engine Error Over 125MpH
