Default Sport Mode for 992?
every modern car with "modes" I have driven is like this. they always start in normal/comfort and you have to toggle a switch or twist a dial to get it in full performance mode. I'm guessing it has to do with emissions, or maybe when someone unfamiliar drives the car they aren't throw in the "deep end". I never found it to be a real issue. twist and shout, as they say.
johnohara (08-08-2023)
Not that ChatGPT could ever be wrong, but here is the actual response. Did it discover something we don't know?
Q: How do I set Sport Mode by default in my 2023 Porsche 911?
A: The process for setting Sport Mode as the default mode on a 2023 Porsche 911 may vary slightly depending on the specific model and equipment. However, here are some general steps that you can follow:
- Start your Porsche 911 and ensure that you are in "Normal" driving mode.
- Press the "Sport" button on the center console to activate Sport mode.
- Press and hold the "Sport" button for a few seconds until you hear a beep. This will activate "Sport Plus" mode, which is an even more aggressive driving mode than regular Sport mode.
- With Sport or Sport Plus mode active, press the "Set" button on the lower right side of the center console.
- Use the up and down arrows on the center console to scroll through the different settings until you find "Sport Mode Default."
- Press the "Set" button again to select "Sport Mode Default."
- Finally, press and hold the "Set" button for a few seconds to confirm your selection and set Sport mode as the default driving mode.
Quikag (05-04-2023)
For those who don't like being conditioned to press one button to get their pellet, another for their water allotment, and another to set Sport mode every time they get in the car, there's T-Design. Do a search on that.
As others have stated, the car has to default to its most miserly settings (Normal, auto start/stop, etc) at every startup in order to gets its emissions and mileage ratings. If more aggressive settings could be saved, the emissions and mileage testers would use those settings and end up generating worse ratings for the car, higher taxes/fees for buyers, and lower sales for the manufacturer.
Wow, that sucks, I didn't know that. Sorry. If you're not the sort to dig into the CAN/LIN bus and hack your way to a solution, there are few remaining options if the aftermarket lets you down.
As you can tell from the thread, most 'owners' have made their peace with their Skinner box. So the market for a button memory module may simply not be there.
Call M Engineering if changing it is worth $2500 to you. And Charles might not do it even if possibly because it is technically altering a emission device??? Not sure.
Basic Sponsor
T-Design9 : Mods and ergonomic accessories bespoke designed for Porsche cars
Memory Modules : remember SC **** settings; A/S/S, PSE, Spoiler, Sport/+ buttons
Phone Mounts : keep your phone up and close and charged
Cupdholders, Sunglass Holsters and more at T-Design9.com
Beware of ChatGPT. In many cases its just 'authoritative bullsh*t'
johnohara (08-06-2023)
not really. My McLaren uses a physical **** and maintains the modes for most. Only exceptions are manual, active aero and dsc
I have a 2021 992 4S. Previously in SPORT Mode the PASM would automatically engage (the red light would activate by the PASM button on the dash). It no longer automatically engages when I change to Sport Mode, and now I have to manually engage the PASM even in Sport. Should PASM automatically engage when putting the car into Sport Mode? Thanks.
AlterZgo (08-06-2023)
