Factory protective front foil
Hi
I’m a week away from the freeze date for a 992 GTS.
http://www.porschecode.com/PRAQ2RS8
I’m just deciding on the factory installed protective front foil, a $5k AUD option.
Does anyone have any recent experience of this and the quality of the install please? Any advice appreciated!
Many thanks
Many thanks
OEM ppf is precut, meaning you will see the line of ppf on the side. A ppf installer can fold it under so you won’t see the difference. Also after ppf, get a ceramic coating for easy maintenance. It should be less expensive that OEM.
My 991.2 GT3 came with factory ppf and I getting it replaced soon as I can see dirt or lift of ppf on side which doesn’t look good.
Hi
Many thanks
Many thanks
