Front license plate bracket
Right now I’m leaning toward this one:
https://skenebrackets.com/pages/gallery
I used it before on my ‘17 Boxter and it has unlimited vertical and angle versatility. You have to drill two small holes in the underside of a horizontal surface that cannot be easily viewed even if the bracket is removed. It’s easier to find the center of the bumper now because of the placement of the camera in the center.
What I don’t like about this is there there is no angle or vertical adjustments allowed. The 992 surface is angled and it has to fit above or below the camera. Right now I’m leaning toward this one:
it allows unlimited angle and vertical adjustments. I used it on my ‘17 718. You have to drill two small holes in the underside of a horizontal surface. Bu they are not noticeable even if the bracket is removed.
I just looked under the front bumper again. It does have those holes that the Carbonio uses for mounting so it will probably work. Th Carbonio photos do not show scale. The holes are only a quarter inch in diameter, not an inch like I thought.
Also I think the plate looks much better mounted below the camera than above it.
The notice on their website says they are closing the business.
I am selling this Carbonio if it works for anyone here:
https://rennlist.com/forums/market/1344453
I have the stick on version on my GT3 now. I leave the plate in my frunk and figure if I get pulled over I can plead my case and reattach on the spot.
As noted in the add... I definitely have the version for ACC somewhere as well. If somebody wants that I can go dig around for where I put it.
Hey I found my OTHER Carbonio mount that I would love to off load. Anyone thinking about this for a car WITH ACC drop me a line. I'm in MA and NH a lot so anyone local will give a great deal...
Carbonio DUO mount for cars with ACC
I have the with ACC version here: Carbonio DUO mount for cars with ACC -- Still available.
I sold the other one.
LMK if this works for you?
Registered User
I was looking for input on this as well, I don't run my front plates daily but I like having a quick and easy way to make it look like I do if needed.
On previous cars I use rho-plate tow hook mounts but I'm not sure if I like the way it works with the placement on the 992
I did some quick research and found this, pricey and still unsure if it's as good of a product as they claim, was hoping to hear if users here have any experience with it
https://carbonio.com/collections/por...31926190473285
I was hoping to avoid the off-center tow hook mount but prioritize durability and am ending up going that way.
Does anyone know if you can order the ACC version of the Carbonio if your car does not have ACC? The non-ACC version of the mount is way more expensive and it looks like it goes under the lip, which reduces ground clearance even further. I'd prefer to mount the plate in the location above where the ACC sensor normally is.
I'm using a Sto and Show. I had one for my previous M4 and was happy with it. Not as elegant as the Carbonio, but not as expensive either. There are options for 992's with and without ACC. I have the non ACC and non-sport bumper and it doesn't require drilling or tape.
Sto and Sho
Sto and Sho
Did you end up ordering it? How did it work?
Read the mounting instructions on their website and you will be able to see why.
The version that clips on tje belly pan only works with that slotted pan. I had a wrong stick on version and the pads hit right where there was an indent.
I'd pay the extra for the right version. Or you will end up like me with $1,000 of hard to return (they are in Canada) mounts selling them on the classifieds...
I have the Carbonio plate, and I find it is a good product with 2 shortcomings:
*Reduces ground clearance
*When attached it is not as sturdy as I would like and often causes the plate to not align parallel with the ground. This is due to the semi flexible plastic plate on the underside of the car to which it attaches, not the product itself.
With that said, I think it is one of the best solutions out there.
But the Non-ACC version (which wouldn't work on the GTS bumper) DOESN'T impact clearance. I put a similar version (my 3rd one) on a 992 GT3.
I wish i knew 90% less about this topic :-)
