A GTS with RAS does most of the weight reduction that lightweight package would do. According to Porsche, the lightweight battery that comes with RAS saves 25kg by itself.
Even if I can't get the lightweight package, the RAS and lightweight glass are the two must have options in my book. The rest are just details. Hopefully Porsche won't have supply issues on RAS and take that away too 🤣👍
You’re right, I’m getting really thrown off! Let me try to get all of this straight. Ok, we know the lightweight lithium-ion battery is 12.75 kg (per one Porsche statement) or 28 lb (per the other Porsche statement). That’s correct because 12.75 kg = 28.1 lb.
The regular battery is either 60 lb / 27 kg (per one Porsche statement) or 38 kg / 83 lb (per the other Porsche statement).
So the lightweight battery saves at least 32 lb.
Now, how much does the RAS system by itself add weight? I’m trying to see how much total the RAS option saves (it saves 32 lb because of the battery but then must add a little weight for the actual RAS).
I've been searching this for a while and have not gotten a definitive answer yet to the weight of the RAS system (without the battery). I've read varying numbers between 7lb and 15lb.
Ok, assuming that’s an accurate range, simply optioning RAS should save between 17-25 lb. This is a way better route than doing the lightweight package if you ask me! Seems like the biggest weight saving is with the battery anyways.
If you have RAS and that $2500 LiON fails, can you replace it with the standard AGM battery? Or is the car and the battery tray/cables locked into the LiON?
As far as I understand it, the RAS requires the power and stability of the Li-ion battery. So it would be a no-go to replace it with the AGM one.
Yea, probably not a good idea. If it works and I think in the best case scenario, it may only work for a while until the extra strain on the standard battery is too much for it to handle. That’s assuming the standard and li-ion batteries have similar outputs.
A year ago there was no option to use AGM or aftermarket LiON. It had to be the $2,500 OEM. I believe Antigravity was looking for a workaround but don't know where they're at.
70ah is the standard battery on a C2S, least in the US. Thats what my car has, genuine Porsche fitted late 2022 under warranty.
That is a good reference and starts to make some sense. Porsche, in the their press release, state that Li-ion battery replaces an equivalent 95 Ah AGM battery and hence the 32lb weight savings. If we speculate, maybe a bigger 95 Ah AGM battery is required for the RAS system and hence the claimed 32lb weight savings over that. But in reality, going from the standard AGM battery to the Li-ion is much less of a weight saving because the standard AGM battery is only a 70 Ah and not the 95 Ah that would be required to power the RAS. So if we assume ~45lb for the standard AGM battery, the true weight savings is ~17lb.
