Thanks. I wish I could tell you but I've only been able to get maybe 50 miles behind the wheel. Will report back when I'm able to get some quality time.
Looks great. Are you happy with the smoothness and glossiness of the finish? Did you do door jams and under hood or rocking a 2 tone?
It looks amazing. No one would ever think this was a "wrap" and it looks like paint because it basically is. It's color coded paint then Akso Nobel clear. Just has a peelable base. Ben really did as much to get it done right. As you can see from the pics he did a lot of sanding. It isnt perfect. There are some spots here and there but nothing I couldn't live with. There are also a lot of swirls from the compound/polishing. I'm gonna give it a few weeks for the clear to fully cure then DIY a correction and coating.
I didn't mess with the hood. Too much work for not enough ROI. Door jams are gonna be wrapped in black olive vinyl which is a spot on color match.
I'm not really digging the bronze with the black olive. Has an old man in a tweed jacket vibe. It wouldn't be so bad if it didn't totally clash with the interior.
Ugh. Looks like I may have to change wheels or get these powdercoated in another color.
The rears are 21x11.5 et50 and will be more aggressive than OEM. The fronts are 20x9.0 et 35 and will be pretty much the same as OEM so not quite as outbound as I'd like.
