Charging a dead battery (locked frunk)
And suggest to your friend to go to dealer and make sure he has the latest ECU update to stop any potential parasitic drain.
I had explained this and I will research the exact procedure and post here. me my CTEK has been on my 992 for 3 months and no worries.
vg247 (03-02-2023)
1.) CTEK charger plugged into cigarette lighter will not charge OR
2.) Porsche with LI-ON battery is dead and won't take a charge.
turboBEVO (03-14-2024)
Every time I have read about this same condition here - the result always seems to be that the cigarette plug charger "shuts down" for various different reasons, the owner is not aware it has shutdown even though plugged in, so the battery goes dead. That doesn't happen with the hard wire solution.
Fullyield (03-01-2023)
GT3's have Rear Wheel Steering which means it also has the Li-Po battery. Most likely his battery is fine, it has gone into Deep Sleep mode.
1) Pull the Fuse Box Cover. Pull out the trunk fuse, its designed to do this (in the owner's manual). Then attach a 12v source to that fuse clamping on either side of it, grounding to the door hinge as Master Deep says. It's going to look like the red fuse in this (997) photo and may be in a different spot, but similar. See the hot leads on each side? Clamp there. Your trunk will now open with the switch.
2) Now you need a booster to "wake up" the battery. If you don't have one, this will more than do the job off Amazon and it will also power that fuse circuit to open the trunk....
https://www.amazon.com/dp/B016UG6PWE...roduct_details
3) Hook it up to the battery and then when ready, press the red exclamation point switch. Upon pressing the switch you will immediately hear the car come to life and it will start right up. Then, carry the booster pack in the car and you can always get yourself out of a jam.
Charging the vehicle with the Porsche supplied charger is a whole different topic and they don't work that well through the 12v plug in, its hit or miss. But the above will get the car going. If the battery is truly dead and does not wake up, its several months before replacements are available.
Received 4,365 Likes
Does anyone know what the CCA (Cold Cramping Amps) are for the Porsche 992 (2021 C2S) AGM battery? I've looked on the battery but for the life of me cannot find it. Just want to test the battery and need the CCA to perform the test. Thanks.
IT is hidden in a sneaky area, the battery type is listed under the black vertical bracket cross bar..my says it’s, AGM
Premium Sponsor
Though there is a specific test for finding the true CCA of a battery, which I won't get into, the fact is that most all the manufacturers are just putting what they feel to gain a sale or make it appear they have higher CCA. But the facts are that if a battery is the same size and same amp hours the CCA will be almost exactly the same regardless of brand. So you can use another brand with the same Amp Hours to get a CCA number for your test. Yes some higher quality brands could use a more pure lead content but that will still not dramatically effect the overall CCA for the battery when comparing new to new. If you are needing the CCA of a battery to use one of those DIGITAL battery testers, I can tell you they are not super accurate to determine anything. The best way to check the batteries health is with a realy load tester that puts and actual load on the battery. Or take it to a Car Parts store to test for you. If I'm off base on what you are trying to accomplish then never mind...
Hi Antigravity - thanks for your response. I was indeed attempting to test my battery with "one of those DIGITAL battery testers". I appreciate the feedback on their accuracy although it's a little bit of a bummer to hear that they are not that accurate.
Premium Sponsor
They generally operate by sending a signal through the battery and measure resistance and give you some results...which being honest probably may work for a down and dirty quick test if your a mechanic trying to see what is up. But when your counting on the device to show if the battery holds a real load which is the end of the line test for us specifically, they didn't work well enough to trust the result. But in another use they might benefit some.
