C2S Delivery and Driving Review!
#31
I second that. Don't go from Full Load down to Comfort without trying Partial Load first. I'm guessing that Comfort was design for markets with low speed limits (Singapore, Hong Kong) or poor roads (developing countries).
#32
I have SPASM and I'm guessing riding on higher pressures is what makes the normal mode feel very stiff for me.
I do feel a difference between normal, sport, and sport plus, it's just not as different as I'd prefer. I think I would prefer normal mode to be a little softer, quieter. Sport mode is basically normal suspension with slightly more pops and crackles. Sport plus basically keeps the RPM around 3000 minimum and the suspension goes stiffer. It seems like a lot of you guys feel a big difference between them, but to me, coming from a big range rover it all feels very stiff already and the differences don't seem all that huge. This is just one week with the car, I think I probably have to spend more time with it to better appreciate the nuances.
18 way the seat cushion itself just doesn't feel as plush and after 1.5 hrs my *** definitely hurts. And I'm used to cycling for hours at a time so it may just be a different type of support I have to get used to.
PDLS+: if I turn the car the nose of the car turns and it feels the light "turns" but it's different than what I'm used to where the light actually shows a dark curvy road's corner upon turning. Maybe I'll get mine checked out. I'd describe it more as because the car is so responsive with steering, the minute I turn the steering the light shows the corner but it's as if the light is a straight extension of a responsive nose, as opposed to a light that bends.
#33
To adjust passenger mirror dipping:
1. Put car in reverse
2. adjust passenger mirror down to where you want
3. that’s it. Put car back in park or drive and it should move back up to where you set it for normal driving.
The following 4 users liked this post by Master Deep:
#34
Triathlonkid (03-01-2023)
#35
You have SPASM, that 10mm lowering comes right out of the suspension travel, so of course the ride is affected by that. Sure, you can play with the tire pressures, but SPASM alone is going to give you a much different ride than the normal suspension (base or S).
#36
Not as much as you think though. I have a C2S with SPASM and my tires set at 33/36 for winter. And it rides very well. I typically leave the suspension in Normal mode and not in Sport. Normal on a SPASM car with comfort pressures is quite a good ride. I can either activate Sport mode or Sport Plus (and then turn the SPASM Sport back off) but I typically drive in Sport and not Sport Plus.
#37
Tires are the first link in your suspension system. Changing pressure, sidewall stiffness, composition, etc. is going to have a noticeable effect. Think about how much better your car rides when you replace old, worn out tires with new ones of the same kind.
#38
OP, just a reminder your GTS has the stiffest 992 suspension rates available in non-Turbo/non-GT cars, so 'comfort' on crappy city streets is not exactly what the car was designed for. Just trying to set expectations that in relative terms a GTS is never gonna be 'comfortable' for the way you are presently driving it (at least in ways that I can respectfully infer from your comments).
#39
He has a C2S.
The following 3 users liked this post by Nein Eleven:
#40
To the OP: from your first post it seems to me that you appreciate the aesthetics of the car and your choices regarding those more than the drive and comfort ? I think you would have been better served by a base Carrera with standard PASM and its smaller wheels along with the noise-insulating glass option. Or (don’t take it it the wrong way) maybe even a Macan GTS to get the Porsche driving experience. Porsche’s sports cars are always about performance first and comfort second no matter how one dresses up these cars with options. Even with standard PASM, sport chassis setting will afford a very stiff ride more suited to track use and not street driving. These are pretty hardcore sports cars and not luxury cars by any stretch. The performance is outstanding but comfort and usability on public streets is not that great. Just my experience after five years with the previous generation of the car. If anything, the 992 with sport PASM is even stiffer than what I remember with the 991.2 version.
The following 2 users liked this post by subwoofer:
jlegelis (03-01-2023),
#41
When can you provide an update on this:
"I wonder if I should have gotten the base carrera, as I can't feel much of a difference in power with the S and maybe the softer suspension is better as a daily driver. Perhaps after driving the S for a while when I go back to a base I'll feel a difference. Will report back in the future on this point"
#42
#43
Nidal (03-02-2023)
#45
