Steel Sunroof
Old 02-05-2023, 10:15 AM
  #31
TuvaD
TuvaD's Avatar
Originally Posted by CodyBigdog
when it squeaks, say, while going over a rough road…if you take your hand and gently put pressure on the edge of the sunroof, does it stop? If it does, might Suggest the seal around the edge of the sunroof?
Yes, it’s the seal. Dealership has sprayed it twice. Might need replacing, I guess.
Old 02-05-2023, 10:26 AM
  #32
CodyBigdog
CodyBigdog's Avatar
Received 2,228 Likes on 1,262 Posts
I was just going to suggest treating the seal…I’ve done that myself with the driver’s side door seal on another car…..but sounds like they already tried that on your car. I guess a seal replacement is the next step. If you’ve decided to do this, and before you have them replace the seal, I might apply some lubricant on the seal, yourself. Easy to do, and you have nothing to lose.
Personally, I’ve never had much luck with service departments, any service departments, actually fixing a squeak….so if I can, I usually end up trying to fix myself. Good luck.
Old 02-05-2023, 11:35 AM
  #33
Z911
Z911's Avatar
How hard is it to swap between the alternative sunroof options? I have the metal one and I’m thinking of swapping it for CF.
Old 02-05-2023, 12:06 PM
  #34
kim9701
kim9701's Avatar
Probably a good question for body shop to answer. But, my GUESS would be that the material cost is about $5000 (CF roof option is $3,890 from the Porsche Configurator). Then, the labor cost is probably another $3000 - $4000.
Old 02-06-2023, 05:16 AM
  #35
TuvaD
TuvaD's Avatar
Which product do you suggest?
Old 02-21-2023, 11:28 AM
  #36
nyca
nyca's Avatar
Gummi Pflege
Amazon Amazon
Old 02-21-2023, 12:56 PM
  #37
CodyBigdog
CodyBigdog's Avatar
Sorry for the delayed response (I haven’t checked this thread in a while).
There are a number of treatments on the market, and sometimes it depends on the compound of the seal where the squeak is. But I have used this before on my rubber door seals….and worked like a champ.
Amazon Amazon
Quick Reply: Steel Sunroof
