992 Change Speedometer Mile to Km (Center Console)
Hi ,
Bought 2022 911 922 S with US Spec from Germany and now trying to change speed in the center console from miles to Kilometer.
Note: that in the setup , then unit, speed already changed to KM. But the Console speeds in miles
Can someone help?
The Center Console
In Setup , the unites have been change to KM
Asem
Can someone help?
The Center Console
Asem
When I did ED with a US spec car, the guys at Leipzig said it wasn’t possible to change the center speed, only the dial on the left side. Perhaps they mean it wasn’t “user-changeable” and a dealer may be able to do it?
I thought that was highly unusual.
Received 2,830 Likes
Not possible, at least according to everything that’s been posted and discussed here by people who’ve had the same issue. Seems that part of the display has the units hardcoded / or actually cut into the display and is not part of the configurable settings.
1100S (01-22-2023)
Hi aggie57, yes I have read some of posts here. But I know certain Porsche model (older) is possible to interchange mph & KM. Since this model is digital, its likely to change.
That's what we all thought too but AFAIK nobody has been able to come up with how to on the 992 short of physically replacing the dial. Happy to be corrected of course.
I had the issue a long time ago and ended up returning the car because of it. You can’t change it yourself. One person here discovered later on, they had the dealer change the “country code” of the car and it worked.
https://rennlist.com/forums/992/1223...l#post18302274
post #38
post #38
The following 2 users liked this post by reddsektor:
aggie57 (01-23-2023),
BadlyDrawnBoy (01-23-2023)
Received 2,644 Likes
post #38
post #38
Change Km to Miles & v/v
Go to touch screen. Touch SETTINGS far right.
Next screen scroll down to SYSTEM.
Next select UNITS.
Then you can reset Kilo. to Miles on speedo / odo.
Centigrade to Fahrenheit on AC
tire pressure to #s & MORE
Next select UNITS.
