Just finished installing the Zunsport grills. First side took a while to get exactly how they clip in, second side 5 minutes. If you go for these, I suggest small pilot holes to guide the screws which hold the uppers in place
Any chance you live in Florida and will install mine?
Only a couple states away. It's actually easier than the RGS grill install. If you can raise the car, easy peasy. I used my FAL, drove up on a 2x6, and worked from the garage lip to make it a little less painful. But I was still sitting on the concrete.
I love the look and 100% convinced that it not just looks as they protect the radiators, but I can’t see myself spending over $300 for 2 pieces of gutter guard wires meshes.
True enough, they're a spendy, but it's a $150K car. The fit and finish are solid, they do protect the otherwise exposed radiators, and compared to just about anything on the 911 option list ($540 for seatbelts, $840 for tach and chrono dials, leather cup holder and fuse box covers) they're quite reasonable. I WOULD argue that Porsche should have provided some kind of standard protective screen as part of the Sport Design front fascia.
Where did you buy them? Direct from Zunsport or did you find a better elsewhere? Thank you.
Agree that the cost is exorbitant for pieces of powder coated , wire mesh attached by ty wraps . However I removed a couple of handfuls of leaves blocking the radiator from a recent long drive.
Definitely a poor design from the factory
Maybe, but factor in the R&D and design costs, costs of tooling and manufacturing, stocking and overhead costs and then consider the limited market. all things considered, I bet this is not a huge profit margin product for them.
SO true. If you think of it, the 911 is only a couple thousand dollars worth of metal, plastic and rubber, so they are a rip-off too. The idea a product should cost only a little more than the sum of the material costs is myopic.
They’re expensive but the intercoolers in my Macan are damaged while I only have one tiny rock hip on my front facia after 30k mi. Damage happens when you’re not looking.
