Rate my final build! VIN is assigned woohoo!
That color/wheel combo is fantastic. One thing you may want to consider is the brightwork around the windows. I think that looks really good with you color wheel combo
Have you driven a GTS? That's a top build. Congrats.
to be honest I had it in my 2020 c4s and never used it. I also never had the race tex headliner so I figured delete the sunroof go slick top and enjoy the full racetex above me.
also I wanted the cabin to sound a bit tighter inside and I think the glass sunroof doesn't help that
The following 3 users liked this post by LaytonNYC:
thank you!
FamousJamisFan (01-05-2023)
I actually really dislike the Burmeister! its too "tinny" sounding for my taste.
I think its over rated. I work in the music industry and prefer the Bose. its a bit more flat and true sounding!
with that said im happy im still below 190k !!
I prob added a few bells and whistles that were un needed like puddles but I was like ehh I do like it so why not?? PICS in feb I hope
I like it, agate on black with yellow accents inside and out with the pccb’s.
Having owned my 2022 911S Cab for only three weeks I’m certainly no expert. However, I would rather have PDCC, FAL, RAS, ACC, and ALK over the PCCB. I’ve never experienced PCCB but they seem a little overkill for a non tracked 911. Maybe on the base Turbo. This is your build and you should get exactly what you want so you won’t ever look back and second guess why you didn’t get this option or that option.
You can get the same softer ride in the GTS as in the S, opting for the zero-cost PASM on the configurator.
Awesome build - it's going to look absolutely stunning!
I love the build! I also spec'd a high build C2S. Enjoy it!!
The only thing I'd say is you should've gone bigger!
If I spec'd that car I would have added the following:
Burmester
leather door handles
FAL(yes I know the front lip is $300 to replace etc)
RAS
Power steer
Carbon steering wheel (although I realize the theme inside is aluminum/external color based)
Glass roof/Extended fuel tank (unless you are trying to go w/ lower weight build)
Burmester
RAS
Power steer
Having a 992 without the RAS and the FAL and now having one with both of these in the new one, I would agree with you here.
I grew up in NY so I know what the roads are like and the places you got to maneuver in and out of and dodging the madness, these two will benefit you tremendously. I’d consider it! Driving a RAS 911 is a totally different experience!
