Rear Axle Steering real world experience?
#32
Per prior posts here (and I checked with Porsche press kit) it only reduces turning circle in slow speed maneuvers by .5 meters.
For me, it was an expensive option, and something else to give you a dash warning down the road.
And the lithium battery is definitely a negative. (See posts on this).
I can't say I miss it in any way.
The following 4 users liked this post by garthg:
#34
I have it on my Taycan and love it. Makes the car a lot easier to handle in tight spaces. For the 911, i don't see much need..
#36
As Andrew Frankel (one of the best car journalists around) wrote when testing the new 992 T ..
The only option I would choose, and it was fitted to the car I drove, is four-wheel steering, something else you cannot get on a standard Carrera. Because when you feel the front end start to slip and you just lift a little to counter it, instead of the car simply biting back into the corner – which would be fine – it instead swivels about its mid-point and flows back onto line instead, which is delicious. The apex to apex rhythm this naturally establishes on a road such as this is an absolute joy.
…Says it all really.
The following 2 users liked this post by Chris3963:
FloraFauna (11-30-2022),
Taffy66 (11-28-2022)
#37
AdamIsAdam (11-28-2022)
#38
#39
- "the only things of value a T has that an S lacks as standard are the locking diff and sports exhaust". The S has either PTV+ or PTV as standard. Only the base Carrera doesn't have either.
- "Remember the S has a considerable amount of additional power, three pedals as standard and the same big wheels and active damping too". Standard transmission on an S is PDK; manual is a no-cost option plus all 992's have active damping (see next point).
- "You can’t get PASM on a Carrera at all." PASM is standard on all 992's; like others before him he's confusing PASM with sports suspension.
On the question at hand, I'm very familiar with Angeles Crest and have taken my manual '20 Carrera S up there a couple of times - other than being an S and no RWS mechanically it's essentially the same as the T he tested. Never do I feel that RWS is missed, the apex-to-apex feeling he describes is there regardless. Where I do think it would help is on the track when the front end can push wide, just like 911's of old. But that's at much higher speeds than we should ever be using on the road.
The following 6 users liked this post by aggie57:
Fullyield (11-28-2022),
minn19 (11-28-2022),
needmoregarage (11-28-2022),
SilverTT (09-19-2023),
TimD (08-31-2023),
and 1 others liked this post.
#41
Almost certainly yes, right? I don't think there is a lightweight battery other than the lithium option - you have to change the storage material since that's the vast majority of the weight.
#42
I had RAS on our previous Cayenne and it is nice for u turns and parking lots as many have mentioned, I thought it felt unnatural in corners. The 911s I’ve test driven with it, it felt much better implemented and I didn’t get that unnatural feeling like I had in the Cayenne. I could take it or leave it if someone is looking for a used 992 and if custom building a car for order I’d personally leave it off. The lithium battery part doesn’t scare me, but it is nice not to have to deal with it. If you track your car a decent amount, I could definitely see someone wanting it and it being a must have option. For the street, I don’t think it is a must have as others have also said, any 911 is plenty easy to do a u turn in or get in and maneuver in/out of parking spaces etc.
#43
Which is the point, if you're trying to avoid RAS solely due to having a lithium battery, it doesn't become part of the pros/cons of ordering the RAS option.
adm63 (11-28-2022)
The following 10 users liked this post by ipse dixit:
AlexCeres (09-24-2024),
Aperture776 (11-16-2023),
fzanicotti (02-22-2024),
Guzzgreg (11-28-2022),
IPA1 (08-31-2023),
and 5 others liked this post.
#45
I drove two 992S’s back-to-back on the track and really did not notice much of a difference. My car is tracked infrequently and even then it is more DE or autoX more so than competitive racing. So, I passed on the option especially with all the lithium battery issues reported here. So I had it but I do not miss RAS at all ……and yet I love a good bacon cheeseburger! Haha.
minn19 (11-28-2022)
