Is there a way to make the steering feel tighter?
Old 10-26-2022, 01:13 AM
ipse dixit
ipse dixit's Avatar
Received 11,774 Likes on 5,139 Posts
Originally Posted by kaylie
BMW has a button u can push to firm up steering.
Too bad we're talking about a Porsche.
The following 3 users liked this post by ipse dixit:
PBoxS986 (10-26-2022), Risley (06-21-2024), westcoastj (10-27-2022)
Old 10-26-2022, 04:26 PM
Denny Swift
Denny Swift's Avatar
Received 1,586 Likes on 670 Posts
Originally Posted by zachr
+1. I actually commented on this to my husband the other day, how relatively small wheel movements almost feel overrepresented at highway speeds. Two factors I suspect were at play: 1) I recently switched from the factory Goodyears to Michelin PS4S and 2) at the time I hadn't lowered my tire pressures back to the comfort pressure level, since the dealer filled them up to the door sill pressures.
Agree, but I think RAS also makes a huge difference
Yeah, but I’ve owned 3 BMWs (Z4, 335, & 435) all with sport suspensions/packages, and the steering feel was just horrible in or out of Sport mode. Most people would have learned without having to buy 3 cars!
Old 10-26-2022, 06:16 PM
michaelp
michaelp's Avatar
Originally Posted by SkipFontaine22
Thank you. I meant just a heavier go-cart feel, more connected. Less steering wheel play.
Which power steering do you have? Plus or normal?
Purekoryo (03-31-2024)
Old 10-26-2022, 06:50 PM
SkipFontaine22
4th Gear
SkipFontaine22's Avatar
Normal.
It seems my tires are overfilled maybe I will release some air.
Old 10-26-2022, 06:57 PM
michaelp
michaelp's Avatar
Normal.
What pressures are you running? There are three pressures settings you can choose from. I’d recommend trying the lowest “Comfort” setting first. Just make sure to set them in the morning, when the tires are completely cold.
Old 10-26-2022, 07:01 PM
Bluehighways
Bluehighways's Avatar
Received 2,687 Likes on 1,264 Posts
Have the alignment checked.
To little, or even a positive Toe adjustment will make the steering feel twitchy. Useful for autocross but not so much for real world driving.
Caster angle will change the "On-Center" feel of the steering, which many owners will describe as being to heavy or to light. Increasing the Caster Angle will increase the "On-Center" feel and to make the steering heavier. To much Caster Angle and the outboard edges of the front tires will begin to develop a "cupping" wear pattern.
Old 10-26-2022, 07:18 PM
NYG1121
NYG1121's Avatar
The real answer is go drive a BMW and then get back into your porsche. Problem solved
CanAutM3 (10-26-2022)
Old 10-26-2022, 07:54 PM
991.1 Guy
991.1 Guy's Avatar
please tell me how to adjust caster on the 992
Old 10-26-2022, 08:44 PM
Bluehighways
Front Suspension, Caster and Camber Angles are adjusted where the top of the McPherson Strut is bolted to the body. See the attached picture.
Porsche provides for a significant amount of range for the Camber Angle adjustment and very little for Caster Adjustment when stock. Notice the oblong shape of the holes that can be seen where the three Adjustment Studs/Nuts come through the frame/body of the car.
Now, the adjustment holes can be modified (within reason) in order to provide additional Caster Adjustment Angle Range. However, short of modifications for competition reasons, falling outside of the range specification Porsche specifies and not having sufficient Range within the original holes generally indicates frame damage and/or an Alignment Machine that is out of calibration or an inexperienced Technician operating the Alignment Machine.
For really serious competition there are aftermarket manufacturers that can supply what are typically called "Camber Adjustment Plates" which replace the section of the body that had the original mounting locations. Not something I would do on a street car.
Old 10-26-2022, 09:32 PM
John Mclane
John Mclane's Avatar
Received 1,390 Likes on 753 Posts
I managed to change the steering feel, with different effort between sport and sport+, by programming it using PIWIS. I no longer have the car to pinpoint which module but I left a screen capture and description on the "coding 992" thread. Sorry that one is a bit long.
It seems to make a difference, the steering became more direct and quite different in sport and sport+.
Edit - post on 9/21/21 on this thread: https://rennlist.com/forums/992/1206...-992-a-25.html
Old 10-27-2022, 06:16 AM
991.1 Guy
991.1 Guy's Avatar
Yes those slots only go left and right. Not forward and back. You would have to remove the strut and wallow out the mounting holes to "adjust" the caster. For practical purposes there is no caster adjustment on a stock 992 strut.
Old 06-21-2024, 01:28 PM
Purekoryo
Purekoryo's Avatar
Maybe try this guy?
https://tarett.com/products/cup-seri...3&gad_source=1
Quick Reply: Is there a way to make the steering feel tighter?
