First scratch - recommendation for LA body shop to fix in LA?
I think it’s totaled.
Received 4,192 Likes
If you can operate a paint can, you can fix that yourself for $ 50 in materials and an hour's work - no one will see it.
cwbrown (02-21-2023)
Premium Sponsor
To repair is properly, as in back to OEM and integrity for many years to come, whole bumper needs to be addressed…small repair and spot blend of color in the damaged area, then clear coat the whole bumper…set you back 1-2.5k depending on how it’s executed
a proficient mobile paint guy however can give you near similar results, by spot blending color AND clear in the general area…this will be under 500 and results MAY last a few years, maybe more
out of pocket avoids carfax for this cosmetic repair
insurance route, most likely will have a carfax AND May raise insurance premium, but check with your carrier
doing a “touch up” diy, not recommended as the color will never look right since it’s metallic, but to some, it’s “good enough”…so not sure what your level of perfection expectation is, but it’s definitely cheapest and least-hassle option if you don’t want to look at an eye sore
I disagree you need a professional repair on that area. I have done dozens of these on everything from Fords to Aston Martins, its quite simple if you have the right materials and some patience, The key is fine sandpaper grits (up to 2000 grit) and priming the area first, Because.the angle of this area is curved to the pavement, it shows no reflectivity and you don’t need to paint the entire panel as you would with an upper flat surface that has high reflectivity. Properly executed with the correct primer, it will last as long as the rest of the paint on the car.
Delete
Don’t fix it because no one will notice it down there. Drive and enjoy the car. If you do, it won’t be the only bumper scratch you experience. Get some touch up paint to hide the contrasting black. Then a little rubbing compound followed by polishing compound.
When you have several scratches on the bumper, THEN seek professional help.
