Color Change Vinyl Wrap Question
There's too much "old man news" floating around in this thread. Modern wraps can look very much like paint and there are a TON of colors to choose from. It wouldn't surprise me in the least if there is someone out there making something that looks just like P Chalk/Crayon. I think you'll be just fine with this option, just make sure you choose a good installer since that will be the difference in how good it looks and how long it will last.
Just three words: Installer. Installer. Installer.
The latest in wraps is liquid wrap which is actually automotive paint sprayed on that can be peeled off just like wrap. I'm getting my GT3 color changed as we speak from Guards Red to Slate Gray. Best option. It looks like paint because it is paint but it can be removed exactly like a wrap. Also, because it's paint, they can color match whatever color you want.
Scott P (01-09-2023)
the newest technology is actually colored PPF which is a wet install and protects like PPF but is colored. 10 year warranty
I have colored PPF on my Macan. Much better than wrap but still has issues. Mostly, it doesn't have as much flex as wrap and seems are necessary in certain areas. Liquid wrap not only doesn't have this issue but, because it's sprayed on, it doesn't have the tension that wrap or PPF films have so adhesion and durability are much higher.
Do you have direct experience with liquid wrap?
That blue is way better than chalk. Keep it stock.
Scott P (07-20-2023)
OP. Are you gonna do it?
There are several cars in my area (Dallas) with Inozetek wraps. It really looks very much like paint. I'm sure installer is key though. I'm very nitpicky and can usually spot the imperfections of wraps within 30 seconds but I was looking at an Inozetek wrapped R8 for several minutes and did not know it was a wrap.
