12 O'clock Marking
Old 09-28-2022, 05:23 PM
d6veteran
d6veteran's Avatar
Default 12 O'clock Marking
My 992 GTS order has the GT Steering wheel. There is a black 12 O'clock Marking on the wheel. Is there a way to configure it so the marking matches the deviated stitching? Or alternatively, is there any after market products to replace it with a colored marking?
Old 09-28-2022, 05:31 PM
991.1 Guy
991.1 Guy's Avatar
The following 6 users liked this post by 991.1 Guy:
CO 992 (09-29-2022), dhirm5 (09-28-2022), k-dogg (09-28-2022), rouxeny (09-28-2022), SamD (09-29-2022), Tedster (03-28-2024) and 1 others liked this post. (Show less...)
Old 09-28-2022, 05:42 PM
d6veteran
d6veteran's Avatar
Originally Posted by 991.1 Guy
lol. Ya that works for older track cars, but this is will be my "modern" track car and am looking for a cleaner look.
Old 09-28-2022, 05:51 PM
991.1 Guy
991.1 Guy's Avatar
The red is almost a perfect match. If you apply it carefully it looks perfect. It may take you a couple of tries to pull it tight enough to get it the exact right width. If you don't like it then you are only out a couple of bucks. I switched from red to yellow for better contrast. Once you get used to having a 12 o'clock, it seems naked without,
Old 09-28-2022, 05:58 PM
kim9701
kim9701's Avatar
I wouldn't mess with it, but I assume a good leather shop can probably paint it. After all, the leather surfaces are all painted anyways.
Old 09-28-2022, 07:12 PM
Staffie Guy
Staffie Guy's Avatar
Received 1,414 Likes on 685 Posts
Not sure how this would turn out- but I would try a thin Sharpie in a nice contrasting color and tape both sides of the wheel so only the stitching shows and carefully color in the stitching on both sides of twelve o'clock markers. Please no flames-just an idea.
Old 09-28-2022, 10:30 PM
shrimp money
shrimp money's Avatar
Received 5,190 Likes on 2,067 Posts
Use gaffers tape, you can get it in yellow.
Old 09-28-2022, 10:46 PM
A Nonce
A Nonce's Avatar
Try this brand instead, effectively Gaffers tape: https://a.co/d/7ULuMzS
If you're covering it on suede this will match it a little bit better since it's made out of a "vinyl coated cloth", so its matte. Bonus is that it should be the perfect width.
However, on leather, I think the 3M 1080/2080 auto vinyl wrap might look better (shiny). Downside is that you're going to have to cut if yourself.
Old 09-28-2022, 10:55 PM
Yojeffo
Yojeffo's Avatar
Default 12 O'clock Marker
Gaffers tape.
Had it in red on my 991.2 for 4 years with NO damage to the leather. I now use yellow on my Targa GTS.
Amazon Amazon
Measure, cut width with scalpel and apply. Surface texture not shiny.... looks like leather.
The following 3 users liked this post by Yojeffo:
CJDCREW (03-24-2024), rouxeny (09-29-2022), Staffie Guy (09-29-2022)
Old 09-28-2022, 11:06 PM
shrimp money
Originally Posted by Yojeffo
Gaffers tape.
Had it in red on my 991.2 for 4 years with NO damage to the leather. I now use yellow on my Targa GTS. Amazon.
Do you need the other 54.9 yards, or can your RL brothers get a piece if we send a self addressed and stamped envelope?
The following 3 users liked this post by shrimp money:
Reata1 (10-02-2022), rouxeny (09-29-2022), Scott P (03-26-2024)
Old 09-29-2022, 01:21 AM
ipse dixit
ipse dixit's Avatar
Received 11,774 Likes on 5,139 Posts
CXX option.
About 4k (at least that was the price for the 991 GT3)
Old 09-29-2022, 02:00 AM
rouxeny
rouxeny's Avatar
Gaffers tape.
Does it leave any residue when you take it off?
Old 09-29-2022, 02:38 AM
BondJ
BondJ's Avatar
It certainly does. Used tape on my track cars back in the day, always left a mess on the wheel. Doesn’t matter on a stripped out crapper but I’d think twice on nice 200k 992…
Old 09-29-2022, 03:02 AM
Bluehighways
Bluehighways's Avatar
Received 2,687 Likes on 1,264 Posts
I used this from Amazon for $2.49.
It was extremely easy to apply and left no residue when I removed it a year later to check.
3M 2080 G13 GLOSS HOT ROD RED 3in x 5in (SAMPLE SIZE) Car Wrap Vinyl Film
Old 09-29-2022, 04:04 PM
APEX GT3
APEX GT3's Avatar
I found that the pin stripe tape worked best with being in the sun. 1/4 in was PERFECT. The glue was not a problem! ...
Amazon Amazon
Ive used another tape on a previous car and had to replace it often because the glue would melt. It's very easy to clean if so.... but best to buy better quality (amazon link above)
Quick Reply: 12 O'clock Marking
