Matrix headlights?
Can someone please explain what the European matrix headlights do that they can't do in the United States? I have them on my Panamera Turbo S and the headlights are fantastic, so I added them to my 911 Carrera 4 GTS build for the extra $2K or whatever it is. But if they aren't any different than the standard 911 headlights I'm thinking why spend the money on the matrix upgrade. Please help and thank you!
As it was explained to me, from a Canadian that had the active matrix on his 992…the matrix headlights have something like 81 individual LED’s than can each be moved independently from other LED’s…allowing the light to be split and focused where it needs to be (based on road and traffic conditions). I’ve seen videos of this movement, and have to say, it’s well worth the extra money….but unfortunately, we in the US have the matrix part of the headlights, just not the “active” part.
With just tjhe matrix portion, the lights are still pretty good, and do have movement while Corning. Just not as good as it could be if fully active
Smirnoff67 (08-02-2022)
Also when turning on they do do this horizontal movement. Pretty cool pulling in the garage at night. I got it merely for the aesthetic of having the latest and greatest.
The non-matrix PDLS headlights pivot as well, moving left/right to help in turns and up/down to help you see further down the road at speed.
Thank you all for explaining. Very much appreciated!
Received 2,842 Likes
The first person to do it will be a RennList folk hero. We'll sit around the campfire and sing songs about them.
I suspect the reason that it hasn't been cracked yet is due to a hardware difference between the US headlights and other regions.
No one has successfully gotten the US matrix headlights to fully function. We have some full-on PIWIS wizards in this forum and money has been no object for others to pay a professional to do it. Even with all of that, still, no success. Unfortunately, I believe that the underlying reason that no one has been able to activate them is the same reason that Porsche can't provide it as a retroactive software update. The US matrix headlights are likely missing something compared to other markets.
For VW, Audi’s, and other VW group cars you use VCDS from Ross-Tech, I used it to add a reversing camera to our ‘14 Beetle. Easy to do, well proven. Seems that this restrictive approach to allowing coding changes is very much a Porsche thing, not VW.
One of the main benefits of the BMW system is that when coming up behind another car, once the system senses there is a car in front of you, it will split the beam so as not to blind the car in front of you, and your high beams can stay on….and will illuminate (more) the areas on the shoulder, and into the other lane. If it senses someone coming in the opposing.other lane, it decreases (does not elliminate it) the illumination in that lane until the oncoming car gets within a certain distance from your car, at which point, all light into that lane is turned off, and then back on again as soon as the car passes. So, while the system does not have the 81 independent LEDS allegedly on the Porsche matrix system, the BMW system does have the ability to not only move the light, but can effectively shape the beam. It’s a very cool safety feature for those that drive on dark roads at night. It really is a total shame that Porsche owners don’t have something similar in the US?
When I drive at night on local country roads, I take my BMW for this reason. The lighting is set to automatic, and starts out in high beam, and adjusts the lighting location, beam shape and intensity, automatically for me, as driving conditions change. I give it a big thumbs up! 👍
I would expect the Porsche active matrix system to be every bit as advanced as the BMW system from 2016,,,when, or if ever activated? If, in fact, as some have suggested, Porsche eliminated some of the hardware on US cars, then quite frankly, that’s totally deceptive advertising. If the required hardware was omitted at the factory, it’s very clear to this consumer that Porsche NEVER intended to have their active matrix in their US cars. If that is the case (which I don’t believe), then they should NOT have asked a $2k+ premium for a system that didn’t exist. If that were true, US buyers never had the active matrix, and never would (Porsche is NOT going to retrofit a bunch of hardware - get real) . My believe that Porsche’s solution, as with BMW, Audi, Mercedes, etc, was to use software to disable or activate on different markets, and the hardware already exists on US cars for those of us that paid for the active matrix. I have to believe, I want to believe that changes in US Federal regulations were already being considered, years ago, and that Porsche marketed their US cars with the possibility (but no guarantees) the system might one day be activated.
But I’m not holding my breath when it comes to what Porsche will, or won’t do to placate customers. So far, I have been unimpressed regarding how Porsche has handled a host of known complaints on other issues with it;s cars (eg. From saggy seat bottoms, to batteries prematurely failing). . Maybe it’s not Porsche’s fault, and they are at the mercy of their slave master, VW?
On some BMW, the hardware in indeed different between US and EU/ROW cars. For instance, it has been confirmed that 2018+ US market BMW F8X series M3/M4 with the icon LED adaptive headlights have different hardware (missing circuitry and LED arrays and differently shaped reflector lenses), so it is not possible to activate the high beam shaping features via coding on these cars to function properly.
The following 2 users liked this post by mystermykee:
Captain P (01-15-2023),
CodyBigdog (01-15-2023)
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1124/img_1420_3045b84c12ec91b539a35486bb6f327db67c6d0a.jpg)
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1124/img_1416_b068812353d3a384a2bc8620df04219c7c3bea09.jpg)
This week I made pictures to compare the design on a GTS.
mikey94025 (01-15-2023)
