location of pyro fuse porsche 992 ( Diagram please )
Hi,
anyone knows where the Pyro fuse is located for the Porsche 992 .
Anyone has a diagram or some information where it’s located .
Thank you
Thank you
Yes. It is in a power distribution block on the passenger compartment side of the firewall at the very far forward end of the center tunnel. You have to remove the dash to access it. There is no other way to get to it. as the SRS connection to the fuse is on the outside of the distribution box cover, while the pyro fuse itself is on the inside.
The only good news is that the fuse only costs about $15 on eBay. It looks like this. Make sure you get the one with the rounded corners with the purple connector - the square version won't fit.
Have a look see at Matt rebuilding a GT3, the fuse is shown in one of early vids in the series
https://youtube.com/playlist?list=PLfxQXU4eWmzUE5Nd8-NBhcuwU0uQib7yd&si=KgjjQuSU4PIRiY6W
