Battery woes
Put my 2020 911 on a lithium Ctek charger and left it for two months. Locked the car which I've been told shut down the system and didn't allow the battery to be charged. (Not sure if that is a fact.) Couldn't get into the car when I returned. After opening the door and attaching a power source to the proper station in the left footwell I was able to open the frunk. And with the power source started the engine. Ran the car for about 50 miles and then put it on the Ctek (with the car unlocked), for about 5 days. The battery shows 13.3 volts but the PCM shows "VEHICLE BATTERY CHARGE IS LOW. SYSTEM WILL BE SHUT DOWN". The car starts but I'm not happy with the message. The battery shows 13,3 volts but I don't know the amperage available. I don't have a drain on the battery. My car is 18 months old and has 7000+ miles. I drive it in winter. Kendall of Bend won't help me. They told me to call 1-800-PORSCHE.
Did that, have it permanently wired with a Ctek quick connect kit. I use one of those that have the red/yellow/green light on the car side of the quick connect. The moment I unplug the charger that light goes yellow blinking, checking the battery voltage it is 12.4V and seems fine. Someone else mentioned these battery indicators on those quick connects are worthless.
I’ve never seen my Li battery voltage (measure in the car by both the instrument display and voltage reading on my radar detector) to drop below 13.2v. Normally bounces between 13.4-13.5v.
Same place you read the oil tem/pressure/turbo pressure/etc
I just customized that display to add the "on board power" and it shows 12.4V. I am not understanding how you can see much more as Lithium battery cells don't get you beyond 12.6V (or I need to relearn what I know about lithium cells)..maybe when car is on and you see charging voltage from alternator?
There was also a long thread about how you can ruin the battery if the negative lead of the charger is connected directly to the negative battery terminal. I cried foul, but was proven wrong by a document that someone posted. (Found this link. See post 22 here):
https://rennlist.com/forums/718-gts-...-tender-2.html
Your link doesn't say anything about 6,000 miles. If anything it clarifies that the battery is covered for 4 years. There is no way that they could deny the coverage based on mileage alone.
2020 992 C4S with RAS
Got a battery warning light. I trickle charge religiously.
Battery holding a 13.4V charge but this is the lithium battery with the integrated battery management module/system.
Car starts fine but I worry that a faulty battery management system might lead to battery drain when parked off a charger.
The fix is replacing the battery because the BMS is part of it, not a separate part or module.
Here's the bad news and why some of you may be waiting for their new 992s and, definitely, why you don't want to have to replace your battery right now.
The battery is out of stock with no eta.
Oh , and it costs $2000.
And Porsche doesn't warranty the battery if you drive less than 6000 miles a year. My dealer, though, is pushing for warranty replacement because technically the battery didn't fail. The BMS did. And the battery was kept on a trickle charger.
Please say something to ease the pain. Summer's coming and I can't drive my favorite car.
- 13.4v is perfectly fine for your lithium to be sitting at, and you say the car is starting fine so it looks all good for now. The BMS can't be said to be bad if your car is starting and it appears to be sitting at a fine voltage. Perhaps the Car's Intelligent Battery Sensor (IBS) is just reading the voltage wrong and giving you a flag. Becuase if your car is starting and the voltage is a 13.4v everything is working on the battery side just fine. That is just where you want to see a lithium battery when it just sitting at resting voltage. Its nominal/resting voltage is 13.2 so 13.4 is right in the pocket.
- Abosoltly NEVER give into Porsche claiming its not covered under Warranty... that is the biggest money making scheme in the Auto Industry.... tell them buzz off , this battery is warrantied for 4 years (if it does ever become the battery) and replace it or your willing to take them to court. The reason I say this is because they tried to burn me like this after buying my GT3 RS.... they try to deny basic Warranty claims I had. Just fight them, they will say OK we'll cover it . Additionally they CANNOT put any statement of having to drive your car any distance as part of a warranty on a battery! Tell them to buzz off and that your Lithium Battery is on a Charger so you don't NEED to drive to keep it perfectly charged and conditioned. 6000 miles of driving have nothing to do with your battery. You can drive 2 miles a year and you battery won't know the difference as long as it is kept charged. Porsche Dealer are not your friends... yes they can be nice as pie, and smile and ask about your kids when they see you again... but they are just there to make money.... and if they lie about a warranty oh well they will do it while acting like your friend.
- You may drain the battery if you don't keep it charged... but sounds like you did keep it charged and its working fine except for a warning you got. Keep in mind that warning could easily come simply because the battery was a little over discharged and then on the start attempt it went down into the 9 or 10v range for a few seconds which will cause the Porsche system to report low voltage or a flag. All I can say is don't worry until you actually see a functional reason to worry because these Porsche Systems are very sensative to the slightest discharge... but they flag sometimes when the battery isn't continously low but just low for a few seconds of time.
Not sure, but I read the same voltage of ~ 13.4v on the battery (no engine running) on both the Porsche instrument panel and the readoff from the radar detector plugged into the car’s cigarette lighter/outlet. Been this way since I got the car. In fact, when I turn on (not starting engine) and watch the voltage over a minute or two, I see NO drop in the voltage.
That said, I found this on a car battery web site:
”A 12-volt lead-acid battery that is fully charged often provides a voltage of about 12.7V. If the lead-acid battery only has 20% left, it will only deliver 11.6V. A fully charged lithium battery delivers 13.6V but delivers 12.9V at 20%.”
I have seen as high as 13.6v, and never in the 12v range. Maybe the 12.6 v you are seeing tells you something, per the comment above, “…delivers 12.9v at 20%”?
All this complexity of battery management makes my head hurt. After delving into these threads and learning, it does appear there is only ONE correct way to do all this, and anything other than that correct way can lead to issues.
Somedays I think I want to return to the analog car days of the 60's and 70's. Then I go drive one of those ancients and ....ahhh..no...Modern is better. lol
Mhm, Ctek says its all charged and green....but voltage on display never goes higher than 12.7V even with charger still on but engine off. I guess another detail for Porsche to figure out. I never see a resting Voltage of 13.6V and I am puzzled by that. I thought LiFePo4 batteries deliver 3.2V per cell aka 12.8V max (not charging voltage). Mhm.
https://diysolarforum.com/threads/li...ge-chart.3156/
13.6v - 14.4v is considered to be 100% charged {I assume Porsche limits the charge so it doesn’t reach higher than 13.6v}?
13.4v (which is what I normally see) is considered to be 99% charged
12.8v is considered to be 17% charged
12.5v is considered to be 14% charged
I found this for LiFePO4 battery:
To chassis ground but not the post they show in the manual as the leads are not long enough of the quick connect. I used a post on the other side closer to battery.
The following is from my service department manager. He was responding to my email that after charging, the ONLY light on the ctek that was lit, was the green power light. It was charging, as seen by the various yellow charging status lights, but when I left the charger and came back in a few hours. None of the status lights were lit, and only the green power button was lit. That was wrong…so i asked him what was up? His response worked and fixed my problem after i moved the negative terminal from the negative post on the battery, the the grounding post. No idea if this will fix your problem, but it might if you connected the ctek to the battery? Give it a try, and see if it helps? Start the trickle charge all over again.
“The negative lead on the charger is to be connected to the negative jump post, and not on the battery. Connecting at the battery can short the battery sensor. I’m not sure if doing this will interrupt the charge-o-mat pro, but it’s certainly possible. The negative jump post is located here on a 992”
