Did you know this about our air filters
https://www.ebay.com/itm/384736558292
Received 4,134 Likes
Autobacs (02-22-2022)
BBI posted a how too on this back in 2020. I used there video to swap mine out. Hardest part is removing the rear tire. And I think this is one of the best soudning mods you can do to a 992. With the BMC filters, you gets lots more turbo whistle noise. Oh how I miss that sound...
Thanks Carlo_Carrera and drcollie. I'm thinking about trying this since it's matte black and hopefully blend in. I'm also going to try to cut to size it on the bottom of the rear bumper. On the 992, it's painted and gets sprayed with gravel.
Amazon rubber pad w adhesive
I personally would not do that, anything with an adhesive strong enough to adhere to exterior paint in a harsh environment such as the underside of a 911 bumper cover is also strong enough to damage the paint if removed. Having paint rash on the bottom of the rear bumper is just part of Porsche ownership. FYI, if you go the wheel well insulation route (Dynamat) it goes on the inside of the wheel well, not in any visible area. or where it can be visibly seen.
https://www.youtube.com/watch?v=6Zh6OjtIRYc
Funny you mention that. I remember thinking the same thing! All I know is, BMC filters are a MUST do. I loved the added turbo whistle at low parking lot speeds. Everyone hears them. = ) Sing turbos sing! Sing to me! lol.
It's going to SOUND faster and your brain will think the car is quicker because of that, but my money is the times will not change. An internal combustion is an air pump. If you put more air in on one end, and don't allow for more air to exit on the other, you will not see performance gains. The most restrictive part of this air pump we have in the cars are the catalytic convertors. Change those out with sports cats and them combine with the BMC air filter and you may see those 0-60 and 0-100 times improve.
Easy Test. Go knock out some 0-60 times, and 0-100, then come back home and change your air filters, repeat the tests and record the times. Do this on the same day, same weather conditions.
