Engine Control Error warning
#31
Received 2,719 Likes
Spend $10 and buy a cheap Scan Tool. Let us know what (if any) Diagnostic Trouble Codes (DTC's) are present.
Ex:
Ex:
#32
This happened twice to me this week on my 2022 C2S. I would go for a drive and park for about an hour, and when I start the car, I get the engine control error warning message. Car seems to drive normally except, rev match seems to be inactive and the dash is showing the wrong gear (e.g. I shift into second and it's displaying 6th gear). If I turn off the car for 30 seconds and restart, engine fault goes away. Wondering if I should bring straight to the dealer or have my local independent look at it first.
#33
Stop wondering, the car is under warranty...
siberian
siberian
Fullyield (04-09-2024)
#34
Folks I am having the same problem where under load there is an engine control fault error popping with the car rattling. After restarting it goes away. Have been to the dealer twice and they are not able to figure out. Has this been finally resolved. I see several other threads with the same issue but no conclusion.
#35
#36
#37
I'm at 650 miles in my 992 C2S and get this little warning sporadically. Shut off the engine and restart and it usually goes away in 10 seconds. I've not tried OBD2 or OBD11 reader too see what it says (or if those even work...)
Any of you seen this one before I take her into the shop?
techartturbos (09-10-2024)
#38
