Discrepancy between lock dates - dealer vs TYD
I originally had a lock date of 7/28/21 on my 992 TTS. More than a few people were reporting that their lock dates were getting pushed back to a later date. I contacted my dealer via email on 8/20/21 to see if the order was, in fact, locked as I wanted to change my exterior color from Chalk to Shark Blue. The dealer responded via email that it was locked.
I hadn’t gotten my TYD information and reached out to Porsche NA. They responded a day ago and I was finally able to access TYD. The most current status on TYD is that my freeze date milestone was reached on 9/17/21
So now I’m wondering what the actual freeze date was and if I could have changed my exterior color when I inquired in August. I have emailed Porsche to see what the real freeze date was. I’m relatively sure they’re not going to let me make the switch at this point but has anyone else seen a large discrepancy between what their dealer stated was the freeze date and what TYD was showing?
The only thing I can tell you is that, as of now, TYD is showing 70 days to delivery and it doesn’t look like the car has entered production as of yet.
This is why I’m upset. I should have been able to make the exterior color change I inquired about on 8/20. I have no idea why the dealer told me (in writing via email) that my build was locked and no other changes could be made.
I doubt Porsche will let me change the color to shark Blue at this point - which is the change I wanted to make on 8/20.
I would think that if you haven’t reached Production Scheduled phase that there is a chance to make the change. Your dealer ought to jump in and push hard for you. Sounds like they were trying to protect a vanilla dealer spec.
Some RL’ers have been able to make changes post lock but it’s not a given. I have a very good dealer relationship and we did some tricky things in getting my build allocated and coordinated around a PTS slot and they weren’t able to add on options after the PTS pseudo-lock.
Dealer has acknowledged that the wrong freeze date was provided to me. It's still unclear if the fault is with the dealer or with Porsche. Whether they can do anything about the change I was planning to make mid-August is still up in the air.
tell them to mail you a pdf of their production tracker. It shows the actual dates Porsche sent to them in a tabular format
I would understand Porsche not wanting to make changes post freeze if you were requesting options like different wheels, etc since suppliers and logistics come into play. But since you are only talking about exterior paint color and the paint robots are engineered to paint any color required with each passing car (ie one red, then next one black, and the next blue, etc), imho changing the color on the order to keep a customer happy should be no issue whatsoever.
In addition, even though it’s a new allocation, I was told that most likely the only change I will be able to make to my current configuration is the exterior color. I’ll post more as things unfold.
Apparently this isn’t the the case. I was told that if they do allow the change (still up in the air) I would have to switch into another allocation with a lock date that is in the future and have to wait an additional amount of time for the car. I haven’t heard anything as of yet.
