992 KEY replacement without Dealer
Hi All,
I am wondering if anyone here is able to get the 992 key programmed with the BCM . This car has no key to insert.
The key we have is the same as the 2020 Cayene and Macan ?
Any help is greatly appreciated . Going to the dealer is way to expensive .
Thank you
Thank you
If you are the owner of the car, Porsche will make you a key. If you are unable to prove ownership, Porsche refusing to make you a key is the system working.
The request and related threads continue to be sketchy, because this sounds like a stolen car.
…and going to the dealer to do this isn’t expensive at all considering the overall cost of the car.
That being said, if you post the VIN number for the car, maybe there’s someone here that can help.
