Oil level gone from porsche connect app
Subscribe
Sep 20, 2021 | 11:50 AM
Porsche connect app used to show oil level? I just noticed it’s gone ,shows fuel level and tire pressure ,no oil level? What happened?carl
Reply 0
Sep 20, 2021 | 12:10 PM
Same here, weird.
Reply 0
Sep 20, 2021 | 12:14 PM
It never was very accurate sometimes it would show you the oils low when it was full. Maybe they just gave up on it? Carl
Reply 0
Sep 20, 2021 | 01:49 PM
Mine's gone too. Here's one for you though that you might have seen where the tire pressures show up accurate to the tenth of a pound.
Happened to me once and then the next time I used the app it was gone. Guess they were trying it out.
PORSCHE! Bring that back! It was awesome!
Reply 0
Sep 20, 2021 | 02:23 PM
Quote: It never was very accurate sometimes it would show you the oils low when it was full. Maybe they just gave up on it? Carl
Don't they just use the same data that you see in the car?
Reply 0
Sep 20, 2021 | 02:28 PM
Quote: Don't they just use the same data that you see in the car?
I guess all I know sometimes it would show low and the car says full and sometimes it would show full? Carl
Reply 0
Sep 20, 2021 | 04:23 PM
Quote: I guess all I know sometimes it would show low and the car says full and sometimes it would show full? Carl
I guess then they don't use the same data . Or something like that!
Reply 0
Sep 24, 2021 | 08:32 PM
I noticed this as well. It seldom matched the actual level on the dash display.
Reply 0
Explore
Oct 2, 2021 | 01:37 PM
Mine is gone too. As opposed to other’s experience here, my car readout and app matched. I guess it doesn’t matter as long as the car displays the information. After my first 6,000 kms, I just got a display notification telling me to “add up to 1L of oil”.
Reply 0
Oct 2, 2021 | 02:34 PM
Quote: Mine is gone too. As opposed to other’s experience here, my car readout and app matched. I guess it doesn’t matter as long as the car displays the information. After my first 6,000 kms, I just got a display notification telling me to “add up to 1L of oil”.
You needed to add 1L of oil after just 6,000kms? Your first 6,000kms?
Reply 0
Oct 2, 2021 | 05:00 PM
Mine would vary quite a bit. I suspect it's a function of when the Porsche Connect algorithm would query the car's dB or when the cars algorithm would refresh the file Porsche Connect addressed for this information. If this happens when the engine is running, I'd imagine the oil level would appear lower than it actually was. If it read the level with the ignition on but the engine off (as the owners manual describes), then the level would probably be quite different. If the existing process had folks adding oil when none was needed, I'd imagine that would be sufficient motivation for Porsche to shut this feature off in Porsche Connect. The "If a tree falls in the forest and no one is there to hear it . . . " solution to the problem at hand.
Reply 0
Oct 2, 2021 | 05:01 PM
Quote: Porsche connect app used to show oil level? I just noticed it’s gone ,shows fuel level and tire pressure ,no oil level? What happened?carl
I send an E-Mail message to Porsche Connect about a week ago concerning this problem using their message utility. Not even the courtesy of a simple reply.
Reply 0
Oct 4, 2021 | 12:14 PM
Quote: I send an E-Mail message to Porsche Connect about a week ago concerning this problem using their message utility. Not even the courtesy of a simple reply.
Finally received response sevens days later - IT IS A QUESTION FOR DEALER - from Porsche Customer Service.
Quote -
Thank you for contacting Porsche with your technical inquiry.
We rely on our authorized Porsche dealerships as our technical resource. With specialized training and support from the factory the service department would be in the best position to address any questions you have.
To find a dealership near you please feel free to use the dealer locator tool by clicking this link.
End Quote.
Reply 0
Oct 4, 2021 | 12:59 PM
My guess is that they just removed it from the app because it had accuracy issues. I have three cars that use the feature, and usually the oil level shown in the app was accurate, but every once in a while it would show very, very low. First few times that happened I checked the car and all was fine. So had been completely ignoring that feature lately anyway.
Reply 0
Subscribe
