992 Dash Cam?
992 Dash Cam?
The recent thread by russbert showing his 992 getting crunched by a lousy semi driver has me considering a dash cam and possibly a rear cam. I figured a dedicated thread may be useful, I know there are references here and there in random threads but I didn’t find a dedicated thread. Any recommendations for one that allows a clean installation?
I've been using Blackvue dash cams in my daily drivers for 7+ years. They work well. Mine did have some hiccups such as memory card corruption issues, but other than that, pretty solid. Blackvue is a leader in cloud technology with their dash cams. Others have better picture quality. For all dash cam needs, I'd recommend following vortexradar.com. He's the expert when it comes to this stuff.
I tried a couple of cameras in the last 10 years. BlackVue is the one that holds its ground. Don't skimp on the SD card, get the one they recommended. Their labeled SD is a Kingston, I use a 128gb.
If you don't get the proper SD, the camera overheats and go bad. I used the 12v on the footwell and tucked the wiring. The rear cam is a bit wasted as I drive a cab, and it seats by the internal rear view mirror.
Don't forget to check the wiretap laws in your state. There's no privacy expected outside. I shutoff the mic when the car goes into service, just in case.
Received 2,719 Likes
I've been using a Garmin Mini-Cam, part number 010-02062-00. Very pleased with its performance and extremely small profile.
Since not all potential damage can be done when you're in the car . . . . you'll probably also want to get what they call the Parking Mode Cable, Part Number 010-12530-03.
Looking into the car through the windshield.
Inside teh car looking behind the rear view mirror.
View of the camera from the drivers seat.
Originally Posted by ajskydiver
When servicing my car, my dealer unplugged my dashcam and didn't plug it back in...
In my prior car, they removed some trim and when putting it back together, they crimped some of the wiring flat.
I like the BlackVue as well, alas they have all started falling off the windshields this summer. And when that happens on the 992, it sets off the alarm. I've tried cleaning, hot water, you name it.. Going with the 3M VHB tape now...
Of note, you are also supposed to re-format the memory cards on a regular basis. Per BlackVue.
I don't think a dealer tech can have an expectation of privacy in someone else's car.
If a cop stops you on the road, then there's no expectation of privacy. Same goes for any given conversation taken outside. A conversation taken inside your car may have the expectancy of privacy, I'm sure there's some Supreme Court ruling in the matter.
Bottom line is, the way I see, shut off the microphone to avoid the aggravation. BlackVue has a feature that you run your hand at the side of the camera and it can do one specific function (like a shortcut). One of the functions is shutoff the mic. Or unplug from the footwell.
Some page turners for sleepless nights:
https://en.m.wikipedia.org/wiki/Tele...consent_states
https://www.mwl-law.com/wp-content/u...IONS-CHART.pdf
I’ve been considering the Cobra Road Scout. Combo Dashcam and radar.
https://www.cobra.com/products/cobra...BoCXMQQAvD_BwE
I have been thinking about a Valentine V1 Gen2 with a Escort M1 dash cam. I realize the M1 is not the best and is overpriced but I think I could power the M1 and the V1 with the same mirror tap. Blendmount sells a nice mounting solution for attaching the M1 to their mounts. Just not sure if the M1 would work with the V1 but you would think it would work.
Yeah good points. I just want to use one mirror tap and I like the Valentine V1 Gen2.
All the Valentines have some seriously strong antennas. Don't feel like you have to put it on the glass. As long as its pointed towards the road (but not necessarily line-of-sight) I think you will be fine to keep it down below. And if you do that then your power options open up significantly.
