Indoor Car Cover
OliverK68 (07-02-2021)
I always keep my car covered in the garage…never put your cover on a dirty car, may scratch the paint…Also, if your car is a cabriolet, may sure the cover does not have any material underneath that would put lint on the convertible top ( I use a lint roller to remove any lint of any type on the top….
I use California Car Company covers, very good quality….
The following 2 users liked this post by richjs43:
detansinn (07-01-2021),
mdrobc1213 (07-06-2021)
Before buying a car cover consider this. I had full front clip PPF applied by a very highly respected PPF installer in Atlanta that does not recommend using car covers ostensibly as it can “cloud” the PPF.
I never verified this with the PPF manufacturer Expel as covering wasn’t that important to me. A quick call to to Expel or other maker can verify or dispel this possible concern.
There is, but if you're taking delivery of the car in the United States, the car takes it's good ole time to get here, sit at port, and get to your dealer. By the time you get your car, that paint will be cured. If you put PPF on after something was freshly painted, there's a good chance that it's going to lift some of the paint.
smiles11 (07-01-2021)
I put the cover on my car multiple times when it had not been cleaned.
Albeit it wasn’t particularly dirty either.
Never had a problem.
So I really don’t see the issue.
Again, I probably will only use the cover in the winter during prolonged periods of not driving.
Loose fitting cotton, only placed when clean, on a perfectly clean car. The tighter and more form fitting it is and the more waterproof it is, the worse it will be for the car.
Skrizzo (03-19-2023)
