Other than the side intake vents the rear of the car is the same. Check Porsches Web Site for vehicle dimensions if in any doubt. Unless the body is shaped differently at the very bottom of the rear fender where it meets the skirt (which I highly doubt), the TTS Side Skirts should fit just fine.
The 992 Turbo/Turbo S are 1.8 inches wider still than the other 992 models.
Koshi makes side skirts that look like the TTS design, and they fit on the 992 if it already has the existing oem side skirts; I believe the Koshi skirt sleeves right over them. A member on the 992 fb group did it on his and it looks awesome.
