2020 Innodrive
Old May 3, 2021 | 02:36 PM
aaoun's Avatar
aaoun
Default 2020 Innodrive
Hey folks
I have a new TTS with innodrive. It seems to work pretty well minus one main (HUGE) issue - it seems to occasionally lose sight of one of the lane lines, and thus veer into the adjacent lane (which is obviously incredibly dangerous). The way I know it's losing sight of the lane is that the lane line on either the left or right stop being green. It also does this without any visual or audio warning to me.
Has anybody seen this? Any tricks to resolve? Anything I'm doing wrong?
Old May 3, 2021 | 02:39 PM
siberian's Avatar
siberian
Disable it?
siberian
Old May 3, 2021 | 02:40 PM
aaoun's Avatar
aaoun
Originally Posted by siberian
Disable it?
siberian
thanks, that was incredibly helpful. i appreciate you taking the time out of your day...i'm sure your time is precious.
Old May 3, 2021 | 02:42 PM
siberian's Avatar
siberian
I meant until you find the time to take it to a dealer. As to why one would want that option or use it, is of course another discourse. Sorry I mentioned the obvious
siberian
Old May 3, 2021 | 02:43 PM
aaoun's Avatar
aaoun
siberian
Appreciate it.
Yeah, I'm not using it until I figure out what's going on. Just trying to understand if this happens to many people or is a bug with mine...
Old May 3, 2021 | 02:45 PM
aquatone's Avatar
aquatone
Originally Posted by aaoun
Hey folks
So far in my limited experience of trying Innodrive I have not had any problems with it keeping the car centered in the lane when going around curves on the freeway. I do know that the implementation in 2020 builds was inferior where it might bounce around the lanes, but in my 2021 it seems to be improved. Main irritant is the 12 second nag message to take control. Its an aid though rather than any kind of autonomy and treat it as such.
Old May 3, 2021 | 02:48 PM
aaoun's Avatar
aaoun
Thanks for the data points. I also have a Tesla, and thus used to AutoPilot, so comparing to that.
Can I ask, when it does lose a lane for you, does it usually give you a warning?
Old May 3, 2021 | 06:29 PM
aquatone's Avatar
aquatone
(I used to have a Tesla (P85D) with Autopilot though that was a couple of years ago and it may have improved) The part of Innodrive that keeps you centered in the lane is ALK (Active Lane Keeping with the steering wheel icon/indicator) which compliments LKA. (Lane Keep Assist with the "between two lines" icon/indicator) I know it's confusing. LKA will issue a lane departure warning if you are not using the turn indicator. If you use the turn indicator, no warning is issued. It's not like Tesla Autopilot where if you use the turn indicator it will move the car to the next lane for you.
Having said that I have not yet encountered a situation where Innodrive "lost" a lane. As it nags you every 10-12 seconds to put your hands on the wheel you are still in effect actively driving and compensating for anything deviating off-course. As said, it's a driving aid and not autonomy in the sense that Tesla tries to promote.
Old May 3, 2021 | 06:30 PM
aaoun's Avatar
aaoun
(I used to have a Tesla (P85D) with Autopilot though that was a couple of years ago and it may have improved) The part of Innodrive that keeps you centered in the lane is ALK (Active Lane Keeping with the steering wheel icon/indicator) which compliments LKA. (Lane Keep Assist with the "car between two lines" icon/indicator) I know it's confusing. LKA will issue a lane departure warning if you are not using the turn indicator. If you use the turn indicator, no warning is issued. It's not like Tesla Autopilot where if you use the turn indicator it will move the car to the next lane for you.
Having said that I have not yet encountered a situation where Innodrive "lost" a lane. As it nags you every 10-12 seconds to put your hands on the wheel you are still in effect actively driving. As said, it's a driving aid and not autonomy in the sense that Tesla tries to promote.
Seems like mine may have an issue. it's "silently failing"...namely it loses one of the two sides of the lane, drifts, but never says anything.
I may have the dealer look at it
Thanks!
Old May 3, 2021 | 06:35 PM
aquatone's Avatar
aquatone
Thanks!
You may want to experiment a bit. I have found the key is to have both the dotted lines (LKA) and steering wheel icon (ALK) illuminated green and active and then it keeps in lane around curves fine. If any one of them is off then.... take control!
Generally, its a bit over-complicated compared to other systems. (Starting with the acronyms)
Old Jun 6, 2021 | 04:28 PM
992TS CAB's Avatar
992TS CAB
Default Inno Drive not working
I had the same issue. Simply go to ACTIVE ASSIST->INNO DRIVE and increase the minimum speed set. Should take care of the issue.
