992 S Manual and Sport Chrono
It appears that the Sport Chrono Package is not available on the 992 S with the manual transmission option selected. I find this to be really odd, and am beginning to think I missed something in the configurator. Can any support my findings?
Jason
Jason
As tgcrun indicates, sport chrono is included w/ the manual. If you select the $2,790 sport chrono pkg, it will remove the manual option and kick you back to the PDK. Also, the manual's sport chrono is missing launch control.
You also can't rely on the configurator pictures as the Carrera S pictures does not show the manual shifter, pedals, sport chrono clock or even the steering wheel mode selector even though you've selected all these options. OTOH, for whatever reason, the correct pictures show up if you start your build from a Carrera 4S model... Very odd since both interiors are exactly identical. Of course on the 4S pictures, it shows a black roof w/ glass sunroof option rather than the correct painted roof that appears with the Carrera S model.
Tedster (04-14-2021)
Jason
I can see value with the PDK but Im struggling to understand where it has applicability when coupled with the MT. I ask this with all seriousness and because Im not a tracker, hard driver. etc.
Is it the added dynamic mounts? Im not really sure how much they change experience either.
Would you pay for it as an option?
thanks!
Bagel, could you advise from personal perspective where technological aspects of the SC is something you actually "use"?
thanks!
thanks!
Additionally, without Sport Chrono you only get a Sport Button, whereas with it, you get the addition of Sport, Sport Plus, and Individual Drive modes.
Received 4,349 Likes
You can definitely feel the Dynamic Engine Mounts when engaged and you are cornering hard - as in near max capable g's. Downside of them is the can - and do - fail and will run appx $ 1,700 per mount out of warranty.
I have Sport Chrono on my 992S Manual and had it on my prior 991.1S manual. I rarely use it unless at the track or autocross. It is the one "must have" option other's will look for at resale on the car.
edit- I stand corrected. After further research, it looks like these are still very much a thing although I’m pretty sure I read this a while ago from a car rag when the 992 came out.
From the configurator, SC features include:
- Porsche Active Driveline Mounts – In Normal mode, magnetorheological driveline mounts remain soft to minimize perceptible vibration of the drivetrain. With SPORT mode switched on, the mounts stiffen for driveline dynamics suiting a sporty driving style. With SPORT PLUS mode switched on, driveline mounts stiffen further for maximum performance.
