remove original rear haunch ppf for full car ppf?
my car is about 1 month old and getting full car ppf done. the car is crayon and there is some dirt on the edges of the orignal ppf patch that came installed with the car. installer is saying i can keep and ppf over it (and it will show cos he may not be able to clean all the dirt along the edge perfectly). or he is suggesting i remove the original ppf as its no longer necessary.
after cleaning and before install he will send me a photo to decide to keep or remove.
thoughts?
thoughts?
thoughts?
thoughts?
thoughts?
thoughts?
Definitely remove the factory film, don’t ppf over it if you are doing full rear quarter. If your installer is even suggesting this, I question if you should get a different installer. If you want, you can double up the film in the high impact area by having installer cut a piece the same size as the factory one.... but it should go on top of the piece covering the full rear quarter.
The following 2 users liked this post by rhr992c4s:
Dan Nagy (03-08-2021),
Schwarz992C4S (03-08-2021)
This is a challenging trade-off. I opted to remove the manufacturer PPF section and just have full PPF installed. I have 1000 miles on my car and I now have about 20 small divots in that area that I believe that the manufacture’s PPF would’ve prevented. I used STEK Dinoshield PPF which is supposed to be pretty darn awesome. However, I think the manufacturer film in that area is much tougher and thicker than most PPF. Though I don’t know what other choice I would’ve had because if I had PPFd over the manufactures film I would’ve had the same 20 divots.The only thing I think they could maybe make sense to prevent visible damage is to somehow reinstall the manufacturers PPF on top of the full body PPF but that seems kind of ridiculous and and I’m not even sure Porsche sells that film as a part. In the end I’m just living with it and not worrying about all those tiny little divots.
The following 3 users liked this post by rhr992c4s:
Note with my 1000 miles the dings I’m seeing in this area are not minor things that can heal. They are significant embeddings that don’t even get better with a heat gun.
A single layer of PPF will probably protect the paint, but it will look like crap quickly. The advantage of doubling up with a 2nd piece the same size as factory is that it can be replaced frequently and cheaply. Porsche does sell the film as a part, not sure what brand they use. It might be 3M. Xpel, Stek, and Suntek
are all better and the computer plotter will cut a piece identical to factory.
Good. That means your installer is competent. I had full PPF - the original rear quarter protector was removed, the PPF went on, and then another second layer like the factory piece went on top of that to better protect the rear haunches.
