Dead Battery Frunk - Help!
#46
You mean like the X3 ESP C40 mandated oil even for us who don't have any GPF's? Yes, there are other components that are not in the 991's but are present in the 992s. And those requiring XC3 ESP C40 oil are........................................? No one seems to know but we must use C40 compliant oils; oh but I digress....
So to recap in case your battery is sleeping -> no lights, engine don't turn over etc:
1) Preferably measure voltage of battery (NOCO does provide their latest booster with a built-in voltmeter; very handy); though I'm sure all of us have a voltmeter of some sort handy
2) If below 10 or 11 volts at rest, connect up the XP-10 for a couple of minutes and check if you now have lights when you disconnect to XP-10
a) If you do, then re-attach the XP-10 and fire it up disconnecting it when the engines comes to life
b) If you don't, then leave it connected a while longer
c) If you still don't...
Is there a particular switch to set on the XP-10 to go onto re-AWAKEN mode rather than START MODE?
As an aside, on a totally discharged AGM battery (6v) 2020 Macan S, it took a CTEK maintainer 3 days to get it back to life. No idea why or what caused that.
siberian
siberian
#47
Premium Sponsor
siberian
siberian
Cody was talking about having the Harness kit and asking how to do it with that... and as I said the Harness kit plugs directly into the XP-10s port which is live... so there is NO protections like if you plug in the Clamps for the XP-10. I don't know how the NOCO operates... I assume it also has some form of bypass button. But NOCO does not have the Harness kit like we make so you would have to do it with clamps... but then if your locked out of your frunk you have to use the Fuse box method to try to get the frunk open. With the XP10 you just plug into the Harness and you have plenty of power to get the Frunk buttons to trigger.
I hope you guys are understanding what I'm saying. It is a bit hard to explain without images.
peterdouglas (03-31-2022)
#48
You have images? ![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
siberian
siberian
#49
Premium Sponsor
I have a question. I do have a similar Ctek quick connect sertup except I use the one with the battery indicators on the plug itself. When I charge my battery all is fine, Ctek says its fully charge within a few hours and all green. However, the moment I disconnect the charger the battery status indicator blinks yellow even though the battery was just fully charged. I connected the quick connect to the + and the negative to a ground post instead the negative battery terminal, but that should not cause anything ?,,,or does the battery shut down and the negative terminal connection can't see any charge anymore as its not directly wired to the battery?
#51
You will also notice after a long drive when you hook up your charger, it will start up from yellow and take awhile to get to green, even though you know your are completely charged from your drive. It is going through the cycles thus will not show instantly green when first plugged in as well.
#52
Your are fine - note the Ctek has the brains in the charger brick. which communicates with the battery. The indicator on just the dongle is somewhat useless (from a voltage reader standpoint) without the brains.
#53
Just trying to read and follow this thread makes me glad I do not have a lithium ion battery.
verstraete (02-09-2023)
#54
Holy crap. Its a good thing this car is pretty.
#55
vg247 (07-05-2023)
vg247 (07-05-2023)
