GMG Racing - 992 TURBO GMG WC-SPORT EXHAUST SYSTEM
Basic Sponsor
GMG is proud to introduce you to our new 992 Turbo GMG WC-Sport Exhaust System for the 992 Turbo and Turbo S! We’ve taken our signature design, used for our Porsche 991.1 & .2 Turbo WC-Sport Exhaust Systems, and combined it with the new factory exhaust layout used on the all new 992 Turbo to re-create our signature sound.
Handcrafted out of T304 Stainless steel and meticulously TIG welded to aerospace specifications with great precision, the system is lighter than the factory. Weighing in at 31 pounds, the GMG Porsche 992 Turbo exhaust system is 15 pounds the factory system.
The system features high flow German made HJS HD 200 cell sport catalysts and a crossover x-pipe to increase power by balancing the exhaust gas pulses from both engine banks. This feature eliminates drone and helps create the signature sound that only the GMG WC system can offer.
The crossover x-pipe works by balancing the exhaust pulses from either side — or cylinder bank – of the engine. It allows the exhaust gases to flow down the path of least resistance while speeding up exhaust velocity. At lower revs, turbulence is formed as exhaust gases try to shuffle past a second column of gases coming from the other side. The X-Pipe merges the exhaust into two uniform streams, allowing a smooth flow from engine to exhaust exit.
Using the factory bracket location, the exhaust system is a direct bolt on replacement for the factory system. To ensure no CEL (Check Engine Light) and proper operation of the vehicle, the HJS HD catalytic converters are OBD2 compliant and the O2 sensor bungs are placed at their proper locations.
Features:
- No check engine lights or engine warnings
- Horsepower and torque increased 24 hp/52 ft-lbs without software upgrade on our in-house mustang dyno cell
- German made HJS high-flow, 200 cell sport catalysts; OBD2 compliant, no CEL (Check Engine Light)
- Crossover X-Pipe to counteract drone
- Constructed out of US Made T304 Stainless steel
- Significant weight savings over the stock system.
- Direct bolt on replacement, All hardware and clamps included
- Requires no modification to vehicle
- Made right here in Southern California
For information or to place an order, please contact us at - 1.714.432.1582 or email Sales@gmgracing.com
gmgracing.com
gmgracing.com
sales@gmgracing.com
www.gmgracing.com
714.432.1582
facebook l instagram l youtube l twitter
Porsche | Audi | Ferrari | Lamborghini | McLaren
Performance Tuning | Motorsport | Factory Service
Pirelli World Challege Race Team GT/GTA/GTS/TC
Pirelli GT3 Cup Trophy USA
Porsche Motorsport — Audi Sport Customer Racing — Lamborghini Super Trofeo Series
sales@gmgracing.com
www.gmgracing.com
714.432.1582
Killer system. What is the od of the piping. What is the od of the cat ?
gmgracing (02-16-2021)
Looks clean and simple, nice work! Pairing this with cat bypass pipes would probably make for the best sounding 992 exhaust note one could hope for.
Two questions:
1) Plans for a OEM compatible valved version?
2) Plans to make this for the Carrera models?
Two questions:
Basic Sponsor
Both are potentially in the works!
A lot of push (I noticed) to create exhausts for the Turbo models.
I guess the Turbo just sounds bad, or maybe owners of Turbos are complaining about it more?
I know people are doing exhaust mods on the Carrera models, but somehow the Turbo has much more of that "vacuum cleaner" sound when revving.
Full disclosure, I've never heard a Turbo revving in person, just online videos
gmgracing (02-24-2021)
Basic Sponsor
@gmgracing Does removing the factory valves trigger a CEL?
@gmgracing Thanks for response but that's not answering the specific question. Does your response mean disconnecting the stock valves DOES trigger a CEL but your system has a solution to prevent it? Or does it mean disconnecting the valves does NOT trigger a CEL to begin with?
Basic Sponsor
Do you get drone in the 1-3K RPM range where the factory valves would normally be closed (or partially closed)
"To ensure no CEL (Check Engine Light) and proper operation of the vehicle, the HJS HD catalytic converters are OBD2 compliant and the O2 sensor bungs are placed at their proper locations."
gmgracing (02-25-2021)
Basic Sponsor
We’re not experiencing any noticeable drone.
