BMC Air Filter Install
Nope, the wheel well housing comes off, 5 torx screws and a 10mm nut. Then 2 more torx screws on the cartridge and pull out. Real simple. Sucks you gotta take the wheel off, but whatever, not that hard.
Some will say there's a HP improvement, but that may be the case but if it is, it's certainly not noticeable.
Zsamboki (02-10-2021)
Also, reusable - you can clean and reuse several times over rather than replace. I use them on many of my cars and I also use them on my UTV - My UTV when we off road and use it for work, the filters get dirty quick. The disposable ones I would have to replace, the BMC's I can clean - re-oil and utilize several times.
